Question about Emerson MW8102SS 1100 Watts Microwave Oven
My Emerson MW8115FS 1450 Watts
My microwave was only 3 months old when it was put in storage. Now that we are using it again, it turns on every time the door is closed, but it doesn't heat. None of the buttons work either!!
  • 38 Answers
Hi your door has hooks which activate switches.one of the switches is called the monitor switch .the purpose of this switch is to close the mwave circuit[complete the circuit] indicating your mwave is safe for use.at present your mwave circuit is open therefore your functions arenot working .check if door hooks are making contact with the switch ,check if the swith is testing continuity.ihope ihave been of assistance let me know cheers
Posted on Feb 08, 2007
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
From memory, they were about 675 watts? Most MW's are between 500 & 1000watts, from "those" days.
Mar 18, 2010 | Emerson MW8675W Microwave Oven
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson 1100 microwave prolonged heating time
the magnatron is going out (this is what warms up the food!( would be cheaper to replace then to fix!)
Dec 09, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Sep 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Jul 13, 2008 | Emerson MW8107WA Microwave Oven
Emerson MW 8115SS
There is a 20 amp replaceable fuse inside the cabinet next to the power cord
Aug 17, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
See answer here: http://www.fixya.com/support/t133065-emerson_mw8115
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
My Emerson MW8115
Hopefully it was not an unheated storage area! Moisture and contamination can get into the controls from condensation due to big changes in air temperatures in areas like unheated storage units or garages. That being said, the most common causes of a failure to heat are in order: - bad door switches or door switch mounts - loose connection at the magnetron - problem with the control unit - bad magnetron or other high voltage part At our site, we have critical safety information, info on door switch diagnosiss and replacement, and disassembly information. You can find us via our listing here on FixYa: http://tinyurl.com/yzjozk
Emerson MW8102SS 1100 Watts Microwave Oven Logo
129 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
