Question about Linksys Wireless-G WRT54G Router
Why does this keep happening??? Please advise...
I have a Linksys Wireless G Router (WRT54G). I have a Comcast Cable modem that is connected to the router with an ethernet cable. I have a Dell laptop that recognizes the wireless network, but when I try to connect to the internet my browser opens but the screen is just white and the internet is not available. If I disconnect the router and run the ethernet cable straight from the Comcast Cable modem into my laptop then the internet works fine. What is the problem and how do I fix it? Thanks for your assistance.
  • 46 Answers
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Posted on Dec 04, 2008
I have comcast cable internet. How do I set up my wireless router to work with this
Connect your router to the Cable Modem using an ethernet cable. On the back of the router, plug the cable into the port labeled "Internet" which should be the port on the far right.
Go to the admin page "192.168.1.1" - change the Internet Connection Type to Automatic Configuration - DHCP.
Feb 07, 2011 | Linksys Wireless-G WRT54G Router
Can not complet setup for Linksys wireless G
You must be using the cable type of isp i guess like comcast,cox or cable vision, Try this Take power cable out from modem and router-
Now PLUG OUT THE CABLE OF POWER TO YOUR MODEM WAIT FOR 2 MINTS. DONT DO ANY THING B4 2MINTS. NOW connect the power cable of router - Hope it may get work- Else try open IE page - type 192.168.1.1 - Press enter - admin is password
leave username blank
Click Mac address clone- Enable- Clone my pc's mac-save settings. Click Wireless - W/l n/w mode mixed - network name - user defined - Channel 6 SSID broadcast - Enabled- Save setings, Click on wireless security on the top under sub tabs of wireless select the wpa security type - make security of your own.
Now do
PLUG OUT THE CABLE OF POWER TO YOUR MODEM WAIT FOR 2 MINTS. DONT DO ANY THING B4 2MINTS. NOW connect the power cable of router.
Mar 30, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Dhcp error using linksys wireless g wrt54g router to comcast
Try to call linksys and they will guide you through trobleshooting steps
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
No more internet thru router after new modem installed
Router setup
Go to the control panel and un-install the program that the Comcast cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Did Comcast reset you wireless router settings? If so, you may need to set up your SSID and security settings.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 05, 2009 | Linksys Wireless-G WRT54G Router
Help please
With Comcast make sure the you clone the MAC address because they use it as a authentication for your internet connection, MAC clone is done on the router setup page eventhough you're using now a DDWRT firmware and after cloning the MAC address on the router page power cycle modem and router for a minute then power on modem first next the router....
Don't forget to rate the solution FIXYA thank you....
Oct 30, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Sep 08, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
150 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
