Question about HP PSC 1210 All-In-One InkJet Printer
Printer wont print
Its says to go to hp toolbox and hit calibrate button where do i find the toolbox
  • gmonc49732 Dec 09, 2008
    Everything was working fine. I changed cartridges and then could not print anymore. I keep getting the check paper light. I checked paper, cleaned the rollers and everything else that looked soiled but I still can't print.
    I need some help.
    Guru:
  • 1,049 Answers
The toolbox software is part of the driver, it wants you to re-run the printer calibration.
Posted on Dec 09, 2008
I am printing the supplies print page but that print alinment was shifted
Calibrates the printer again and again to align
Calibrating the printer using HP Toolbox
Use the following steps to calibrate the printer using HP Toolbox.
1 Open the HP Toolbox.
2 On the Troubleshooting tab, click Calibrate now.
Calibrating the printer at the control panel
Use the following steps to calibrate the printer using the printer control panel.
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select SYSTEM SETUP and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select PRINT QUALITY and then press (SELECT). CALIBRATE COLOR will display on the control panel.
3 Press (SELECT).
4 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select CALIBRATE NOW and then
press (SELECT).
5 Press (SELECT) to start the calibration.
Aug 19, 2011 | HP Color LaserJet 2600n Printer
K5400 warning lights indicated print head problems. I have cleaned the print heads and reinstalled them and I am back in business but now it's doing a test print on every occasion.
Try doing an alignment with the printheads.
You can also try changing the inks,if that solves the problem eventhough old inks are stil not empty,contacts might be the issue on old inks which causes error blinking lights which is an indication of printhead rejection.
Method one: Clean printheads in Solution Center
  1. Make sure the printer is loaded with unused white paper.
  2. In HP Solution Center , click Settings , and then click Printer Toolbox .
  3. Select the Services tab, and then click Clean Printheads .
Method two: Clean printheads from the control panel
  2. Press and hold the Power button
  3. Press the Cancel button two times.
  4. Press the Resume button one time.
  5. Release the Power button
    Cleaning the printheads takes a few minutes, and when it completes, a page prints.
Method one: Calibrate linefeed in Solution Center
  2. Open HP Solution Center , then click Settings , then Printer Toolbox .
  3. Select the Services tab.
  4. Click Calibrate Linefeed .
  5. An Advance Linefeed Calibration window opens. Click OK .
  6. After calibration, print another PQ Diagnostic. If there are still dark lines or white gaps in Test Pattern 3, the printer must be serviced.
Method two: Calibrate linefeed from the control panel
  1. Press and hold the Power button
  2. Press the Cancel button fourteen times.
  3. Press the Resume button six times.
  4. Release the Power button
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP OfficeJet Pro K5400dn Photo Printer
I need to calibrate my hp deskjet 3845 but when I click the button to calibrate it says it's lost communication with the device
Hello
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox .
Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Jan 16, 2011 | HP Deskjet 3845 InkJet Printer
How do one correct print quality in hp color laser jet 2600n
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
Oct 26, 2010 | HP Color LaserJet 2600n Printer
Black cartridge is new,magenta is new blue is halfway and yellow is halfway but the hp color laser jet 2600n prints lighter and black prints as it is finished
Hi Good day!!
Press (SELECT).
Oct 26, 2010 | Office Equipment & Supplies
Prints one or two lines then you get a scrambled error message and it stops until you press on button then it does the same thing again, I have unplugged everything several times and even uninstalled and...
Use the HP Toolbox to perform the following tasks:
  • Calibrate the printer to align the print cartridges.
  • Clean the print cartridges when lines and dots are missing from your printout.
  • Print a test page to check for clarity after cleaning or to verify that the printer can receive data and print from the computer correctly.
  • Print a diagnostic page to show how the print cartridge nozzles are working.
  • Calibrate the photo tray to correctly position your photos.
  • Check the ink levels of the print cartridges. Adjust the printer configuration.
  • Investigate warning conditions.
Opening the HP Toolbox from the printer icon
  1. Double-click the HP Digital Imaging Monitor and make sure you are on the correct printer tab.
  2. Click Settings and then click Print Settings .
  3. Click the Printer Toolbox choice.
Opening the HP Toolbox from the Printer Properties
  1. Click Start .
  2. Click Settings .
  3. Click Printers .
  4. Right-click the icon of the printer in use.
  5. Click Printing Preferences .
  6. Click the Features tab.
  7. Click the Printer Services button.
Oct 25, 2010 | HP PSC 2355v All-In-One InkJet Printer
My HP color LaserJet 2500L printer will only print yellow or black. All the toners are good and the machine has been re-calibrated and cleaned but it will not print full color
Print cartridges might be improperly installed. Remove the print cartridge for the color that is printing inconsistently and reinstall it. im sure you tried this already, but thats from the manual. also check your settings in the computer verify greyscale is not selected. also. Re-calibrate anyway To calibrate the printer from the HP Color LaserJet 2500 Toolbox 1 Open the HP Color LaserJet 2500 Toolbox in one of these ways: • On the desktop, double-click the HP Color LaserJet 2500 Toolbox icon. • On the Start menu, point to Programs, point to HP Color LaserJet 2500, and choose the HP Color LaserJet 2500 Toolbox. 2 On the Troubleshooting tab, click Diagnostic Tools (on the left side of the screen). 3 Click Color Calibration. Then try a test page. if all else fails Try this The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state.
Aug 27, 2010 | HP LaserJet 2500 Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
I have the hp d1400 series...it wont print and its telling me i have an alignment problem..it all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
HP PSC 1210 All-In-One InkJet Printer Logo
193 people viewed this question
Seeker5211
Seeker5211
