Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater will not fire.
I have a reddy heater model 100a. Fires only once and a while but will not stay running. I have installed a new fuel pump filter kit. Breather is new. Nozzle is new. Spark plug is new. Fuel is fresh and fuel pressure is 3 psi. Spark is very strong (Blue) in fact. What am I missing??
  • 1 more comment
  • williamgarne Dec 07, 2008
    Have been busy sorry I did not get back to you sooner.
    You were right. In my haste to put the heater back together I put the nozzle seal in the wrong place. I was pumping pressure into the fuel tank instead of pulling a vacuum. Thanks for the prompt help.
    Bill Garner
    Tupelo, Ms.
  • Anonymous Feb 22, 2009
    I have a similar problem with my 35,000 btu reddy heater. The spark plug keeps getting fouled up. I keep cleaning it and it keeps getting something building up on the electrode of the spark plug until it bridges the gap and then it wont fire. Clean it up and its ok again for a while. The plug gets build up on it right where the fuel hits it. Works ok for a few days, then it gets harder to light, finally it wont light at all and i have to remove the cover and clean the plug.
  • Anonymous Mar 14, 2014
    Disassembled and cleaned pump assembly. Installed LP gauge as recommended. Pressure only reaches 3 psi. Made sure reassembly is correct,checked for leaks and all looks good. 3.6 psi is specified pressure. Thanks for your help
  • 181 Answers
Sounds like the nozzle has a piece of dirt in it not letting the fuel spray to go wide enough to ignite every time.disconnect the fuel line and air line from nozzle.take spark plug out and remove the three screws that attach the nozzla from combustion chamber.put nozzle assy. in vise to hold it still.take a 5/8" socket and remove the brass nozzle from holder.put brass nozzle in vise tip down and remove inner assy.from nozzle.use a pair of pliers.inner assy. isn't in very tight.just loosen don't take it out yet.............remove brass nozzle from vise and turn it over so the assy. is facing down.make sure you have it over some thing so you don't lose the parts inside.now unscrew assy. inside you will find a silver colored piece with notches on the front.THAT IS THE NOZZLE...carefully blow air through the front tip then look through it.should be a clean round hole.once it is clean reinstall in reverse order as you took it apart.don't get to carried away with tightening the assy. back in brass nozzle.JUST SNUG.then try to fire the unit again.should work now.
Posted on Feb 17, 2009
I have a 150,000 BTU kerosene heater that sometimes will fire and sometimes it will not. If I tap on the transformer it will ignite. Somebody told me that usually if it is the transformer, that they are usually good or bad.
Posted on Feb 05, 2009
    Problem Solver:
  • 4 Answers
I had a similar problem with mine a few years ago. After a close look, I found a hairline crack in the cast aluminum burner head. I didnt think it was anything, but it throws off the pressure. Mine would work fine with the cover removed also. I was told that if it works with the cover off, most likely there is an airleak somewhere. Make sure your fuel lines aren't cracked or sealing properly on the fittings.
Posted on Jan 28, 2009
  • 232 Answers
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Posted on Dec 04, 2008
  • Jerry Magee
    Jerry Magee Dec 07, 2008
    That'll do it every time!
When unit fires i get a short burst of fuel then nothing
Clean, waterless fuel and correct air pump pressure are absolutely a requirement for a good running heater. Drain the tank, set the air pump pressure. Your problem could be more serious, such as losing air between the pump & nozzle, a worn nozzle, or a restricted fuel filter.
Nov 26, 2010 | Reddy R155D Utility Heater
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
I have an older reddy heater pro 100 kerosene space heater,
You Must set the pump pressure quickly! If allowed to run with the nose cone a "bright" cherry red the welds will deterioate to the point that the end will separate from the combustion chamber. Individual sheet metal parts of the chamber are not available.
Learn how to properly set the air pump pressure
Feb 25, 2009 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater teasing me:)
sound like there is dirt and stuff in the fuel tank.when the heater fires up it pulls this stuff up into the filter.as it runs it plugs the filter off causing the heater to shut off.whe it shuts off the garbage falls back into the tank.when you refire the heater it pulls the garbage back up again.it never pulls it up the same so the time verys every time
Feb 18, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
When heater starts it does not always light, I get a C3 code
the ignitor is faulty, mine also did that and I noticed one night that it was shorting out right from the ignition box. I put in a new ignitor and flame sensor and it's fine now. All ignitors are basically the same you just have to do some creative wireing. reddyparts.com still has most parts for your heater.
Jan 20, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a reddy heater model R70 that wont ignite.
I have the same problem. What is the matter with it? It seems like it will not pump fuel.
Dec 31, 2008 | Reddy Heater R70 Portable Forced Air Space...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
351 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
