it came with a cord that looks like this its see through inside some type of braided cord one end is usb that end lights up green other end cord runs into top of this end directly next to it on same end large input jacknow smae end going out male large headphone jack basically i cant remember the name of myu sony device i do know for sure there are different pakages for making music but eventualy they all come together but mine is for vocals. help
Please explain:
You have a Sony mic with a USB plug on one end and a 1/4 phone jack on the other? Obviously the USB plug goes into your PC and the 1/4 inch end goes into the microphone or accepts a standard audio cable, commonly known as a guitar cable.
You want to record vocals using the mic, right?
What kind of a PC and what kind of audio capture software are you using?
Obviously the mic is made to feed directly into the computer. The green light indicates it's getting power from the USB bus.
What exactly IS the problem?
Re-20 has a loose part ... and i cannot open it to see what the issue is... there is no screw on the...
(More)
Re-20 has a loose part ... and i cannot open it to see what the issue is... there is no screw on the outside near the front of the mic...
I used a converter for the big jack to a mini jack for computers. Then put the mini jack in my...
(More)
I used a converter for the big jack to a mini jack for computers. Then put the mini jack in my computer and tried recording, it doesn't work (actual mic philips SBC ME570 works normal), the test doesn't work either. What can I do?
how do i change songs from ma headset mm400 sennheiser,,also why when i connect the headset the...
(More)
how do i change songs from ma headset mm400 sennheiser,,also why when i connect the headset the volume on my iphone goes haft way?
