My Camcorder Won't Detect A video Tape. Can you give me instructions to fix it?
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
When I playback my videos, the picture is obscured by a series of thick black lines
Hello
Just to clarify, does the footage look something like THIS?
If this is what you are experiencing, it is a result of "Dirty" heads.
If you have a head cleaning tape, run this through as per instructions.
If you don't have one, buy one.
This should fix it.
Please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Jun 24, 2010 | Panasonic NV-GS11gc Mini DV Digital...
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
Camcorder panasonic displays dew detect in red
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
Jan 14, 2009 | Panasonic PV-GS39 Mini DV Digital...
Mini dv
mam try to check the tape if its correctly inserted to the camcorder. it must the tape itself or the tape compartment has the problem. insert the tape and see if its feed to the tape head and be sure that it will close with no problems. if the problem still occuring or persisting then try another dv tape and see if you got the same problem. otherwise go to the nearest repair shop to be able to fix with the use of their tools. hope that helps you ma'm!
thank you for using fixya
CHARCOIS
Dec 10, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Cant put tape in camcorder
Then remove the tape and check it in another camcorder.....
............. Very simple.
If the tape works fine in another camcorder then throw this camcorder. Let me know the location where you will through it.
May 07, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Advise
Will the tape fast forward or rewind? If so, I don't know the the problem. If it either won't FF or REW the tape, there is a problem that can't be fixed without taking it somewhere to be fixed.
Please rate my help. Thanks!
Feb 03, 2008 | Samsung SC-L770 Camcorder
Panasonic Nv-GS3
I have the same problem, i was just using my camcorder and when i changed the tape, it says incompatble tape and now it wont play or record at all. It has happened to me today.My friend told me to leave for a while and try again. Hi C8dee, is your camcorder working, any updates, did you find a solution. jinn666@hotmail.com
Mar 30, 2007 | Panasonic NV-GS3B Mini DV Digital...
Computers & Internet Logo
22 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
