Alpine CDA 9886 car stereo with sirius. The Artist and song title does not display even though Sirius signal DOES come in. On the other hand, the name of the channel does correctly display (i.e. "NPR").
  • i700plus Feb 01, 2009
    The same exact problem with a SIR-ALP1 adapter and a alpine cda-9886 head unit. I called Sirius and they were not at all helpful.
I read the manual and found out that the reason the track title information does not display is because you need to set the text scroll setting to manual.
Go to settings
Display
Text Scroll
set this to manual.
Should be fixed!
Posted on Feb 01, 2009
Alpine 9886 with sirius interface
This problem sounds very sirius. Sorry, couldn't resist, but "siriusly", the song alert feature is supposed to be something you select yourself, so it locates a particular song whenever it is played on the service. Do you recall setting this?
Are you using the Alpine KCA-SC100 tuner or another?
I would try resetting the radio too.
Dec 13, 2013 | Alpine Car Audio & Video
How do i fix 2014 nissan altima radio song and title display
What do you mean by "fix" the display, is it not showing it? If so- my Nissan Altima has not been displaying Sirius XM Title and Artist for months. After much searching of the internet, I finally found an answer that worked! Just be sure to write down your radio/sirius presets before you reset the radio - it'll clear them all (and the time). The answer is here- http://incodesystems.com/Troubleshoot/Cars/RadioInitialize.htm
Dec 04, 2013 | Cars & Trucks
I have had my Alpine CDA-9886 unit in my 2004 Nissan Pathfinder since January, with no issues whatsoever. Yesterday, i went to get gas, filled up, and got back on the road, for some reason now, my...
you need to reset the sirius alpine adapter, just remuve the positive (red) from battery terminal under the hood for 2 mins, or find the yellow power wire from the adaptor and disconec for 1 min.
Sep 08, 2010 | Alpine CDA-9886 Car CD/ MP3 Player
How to hook up a sirius radio to a alpine ada105 car stereo do i need any interface cables or anything else the stereo is sat radio ready
you shouldnt have to purchase any other cables to hook up sirus however somtimes due to the changes in the manufactor weather it be xm or sirius you may come across your radio not interfacting with the package you bought you might want to check the manufacture about this sirius 99 percent of the time will hook up to most JVC Alpine, Kenwood, ECT but you need to look at the back of your reciever at your connections on the back you should have in output and or input for for either aux in the back such as for a cd changer or in your case that will be used for your sirius hook up. My names Josh and i hope your able to get it figured out.
Mar 05, 2010 | Alpine CDA-7892 CD Player
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
Have an alpine 9886 stereo and cannot connect my blue tooth ready phone...
Hello maslynab,
The Alpine CDA-9886 is Bluetooth ready but requires an adapter such as Alpine's KCE-400BT or a generic adapter in order to pair with a phone.
Hope this helps.
Aug 05, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Alpine CDA 9835
Sounds like you lost the power on your memory wire (yellow) some how. Check power on both the red ad yellow and make sure that you have 12v going to both.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Alpine CDA-9835 CD Player
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
I DID TONS OF RESEARCH FOR YOU ABOUT THESE RADIOS. THE SAME PROBLEM YOU HAVE ARE FOUND BY 100'S OF OTHERS. IT'S THE COMPANY THEMSELVES HAVING DIFFICULTIES.
Sep 14, 2008 | Alpine CDA-9856 CD Player
Intermittant display of song title and artist
I believe it's actually a firmware issue with the SIR-KEN1. I havethe same setup and have the same exact problem. I have to cycle thru my "SRC" button and get back to Sirius for it to work. Not a happy camper. I read on the Sirius Backstage forums about the firmware, although I have written Directed Electronics (SIR-KEN1 manufacturer) and never received a response.
Nov 12, 2006 | Kenwood SIR-KEN1 SIRIUS Radio Receiver
116 people viewed this question
 Grubhead
Grubhead
