Dose not turn on has a full charge - Audio Players & Recorders
  • Anonymous Dec 17, 2008
    fully charged but will not boot up any ideas from anybody thanks
Once you open the device, it's not possible to reassemble it to "factory condition" - in other owrds, this device is not supposed to be stripped and worked on. This problem goes to a faulty battery cable to circuit board inside the device - the battery has a two pin micro-plug to conenct to the circuitry, but the pins are too short to 'home' properly under vibration, or shock (you dropped it) - results in low contact conductivity and a discharged battery. Even though the device reports a Full Battery while on the USB cable, and will show its files under the Windows O/S, the battery pins are not making enough electrical contact. I've opend and debugged mine, and now I'll throw it away - way to expensive in worshop time to worry about.
Posted on Dec 14, 2008
I have a golden 3 wheel scooter dose charger
If the charger is working correctly, it should turn itself off automatically (may go into float chrarge depending on type of charger). There should be an LED or an amp meter on the charger to tell you when the charge is complete. When the batteries are charged, you should be able to leave the charger switched on and it should cause no harm UNLESS the charger is faulty, in which case it will continue charging and damage the batteries. You should be able to tell if this is happening as the batteries will become very warm. If the batteries are losing their charge after you have switched the charger off, it is most likely that your batteries need replacing. Failing that, you may have a short somewhere which unfortunately, could be difficult to find.
Mar 10, 2010 | Electric Health & Beauty
Phone wont turn on, when it dose turn on turns its self back off and wont charge?
Have you checked the battery? May be it is very weak and that's why its not charging your phone.
Try to get some using the same battery with your phone, borrow his or her battery, and test it with your phone to confirm if the fault is from the battery or not.
And if you don't find someone to borrow you the battery, simply look for a desktop battery charger, remove the battery from the phone and charge till it gets full then insert the battery back into the phone and power it to see if it turns on.
Take care.
Nov 23, 2009 | Sony Ericsson Walkman® W610i Cellular...
My lg cu920 phone reads a full charge for a second and then shuts down.
charge ur battery with external charger wich can charge ur battery with out phone if it works thats mean ur phone is not charging ur battery clean the battery terminal at phone and at the battery also or if it dose the same thing then change ur battery cuz its not holing charge ...
Oct 10, 2009 | LG Vu CU920 Cellular Phone
2002 gsxr 600 bike shuts off
Did you put a full charge on the battery b4 you put it in? The charging system really dose not charge until like 4 or 5 thousand RPM's. So just starting it in the garage doesnt really charge the battery. Put a full charge on it and it should be fine.Also buy a trickle charger. It will keep this from happening again. Its a commonly over looked issue. If it dies again going around town the replace the stator. ( left side of motor )
Sep 05, 2009 | 2002 Suzuki GSX-R 600 M
Mi k8001 battery has been dieing really qwickly wen iv had it on charge for hours and know it dose not turn on att all and the red light just keeps flashing when i try switching it on :S HELP ME ...
the reason why is because when you have charged it you might bot of let the battery go down totaly and kept on charging it when it was just half full so it might think to it self "oh ok i'm always going to be charged half way so it will just go straight down and think that is when the batterie energy is gone down" Good luck!!!
Jul 14, 2009 | Sony Ericsson K800i Cellular Phone
Altinator dose not charge when battry is low
time for another battery. Have a load test done on battery. Then have someone fullfield the alternator to see if its operating correctly
Jul 13, 2009 | 1987 Toyota Land Cruiser
Every time i try to turn on my Gateway model MA7
  • the battery may need full charging, charge it for 4-5 hours, and it the problem persist it needs replacement.
  • for it works in power cord.
May 03, 2009 | Computers & Internet
Nintendo ds lite wont stay turned on
the DS might be wrong try charging it overnight if this dose not work than the battery pack in your ds is spoiled this happens over time wile you have your ds if charging dose not work go to a game stop and have them change the battery pack. Hope this helps!
your friend
cutECAT333
Jan 29, 2009 | Nintendo DS Lite Console
 Grubhead
Grubhead
