Question about Philips 42FD9932 42 in. Plasma Television
Vertical black line approx 3" in centre of screen with white line through centre.
I am looking for any advice on what the problem could be with my philips plasma tv. I have had it approx 3 years and now i am experiencing a thick black line running through the middle of the screen with a white/red/green line running through that. I would appreciate any ideas to what could be causing this and any advice on what it may cost to repair? If its expensive to repair should i just forget about it? The tv cost over £4000 when i bought it. The model I have is actually 42fd9945/01, but this is my fist time using the site and could not work out how to ask specifically about this model. Any help much appreciated!!!
  • devastated Nov 12, 2007
    HI I have a similar problem except my tv has a white vertical line running down the middle of it. Do you suggest the same- that it needs a new panel which will cost more than the TV itself.
    Please help
    Thanks
    Devastated.
  • 105 Answers
You will need a new panel wich will cost you more than the tv itself.
Posted on Oct 14, 2007
SOURCE:
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
3" vertical line down right side of tv
Answer depends on model number of set which is not indicated here.
Apr 03, 2012 | Sylvania Televison & Video
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
3-4" thick vertical line on 42" sanyo plasma tv
its most likly caused by either vert controler along bottom of set or ribbon to that part of the controler if you heard a hissing sound most likly is the controler itself
Jan 28, 2010 | LG 42PC3D 42 in. Plasma Television
Only top half of screen has picture there is a white line through the centre and bottom half black
If this is a conventional TV with the original style Cathode Ray tube, this fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around £70 ($120), possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it will certainly damage the tube if you leave it running with that white line through the centre!!!
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the white line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Nov 17, 2009 | Televison & Video
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Philips 42FD9932 42 in. Plasma Television Logo
330 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
