Question about HP Compaq Business nx6125 Notebook
Bios password screen popped up, will not reset
Your solution is on target to reset BIOS by disconnecting battery. The problem still exit is found batteryinside hard wired.???? Is this the coerrect battery? Where is it located on the computer?
Modadie55@hotmail.com
Taking out the bios battery does not reset the system. how do i reset the system
Posted on Jan 02, 2009
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Unlock hdd/ssd password on toshiba satellite
Step 1Turn on your laptop. Press the "F2" key when the first loading screen appears. This will load the BIOS. You'll only have a second or two to press this key before Windows begins to boot. If you're not fast enough and the Windows screen comes up, simply restart and try again.
Step 2Use the right-arrow key to highlight the "Security" tab. This is the third tab from the right.
Step 3Press the down-arrow to enter the Security Settings menu. Scroll down to "User Password," listed beneath the "HDD/SSD Password Select." This will open a pop-up window with three text fields.
Step 4Type your current password into the "Current Password" field. Press "Enter." Type your new password into the "New Password" field and press "Enter." Type the same password again into the "Confirm New Password" field and press "Enter." The "Password" window will close.
Step 5Press the "F10" key to save your new settings and exit the BIOS. Your laptop will now boot normally.
TipHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
Mar 24, 2012 | Toshiba Computers & Internet
Clearing the bios password
When you first turn your computer on, you are briefly presented with a BIOS "splash" screen. Somewhere on this screen (just where depends on the manufacturer), are instructions on how to access BIOS settings. Generally, this requires tapping a function key, say F2, while the splash screen is visible. Make note of which key the splash screen says to press to access the BIOS and restart your computer.
When the computer boots and the splash screen appears, tap the required function key quickly to enter the BIOS settings screen. You will only have a couple of seconds to hit the right key and if you miss it you'll have to restart the computer and try it again.
Once you successfully enter the BIOS settings screen, use the arrow and function keys to navigate the menus. Keep an eye out for an option that says something akin to "reset to factory defaults." If you see this, follow the on-screen instructions to reset the BIOS to the factory settings. Then, confirm your choice and exit the BIOS screen, usually by pressing escape. Congratulations, you are done.
If your BIOS does not have an option to return to factory settings, things are more difficult. Because the BIOS is stored in ROM, it must have a constant power supply to store any changes you make to it, otherwise it would reset every time you disconnected your laptop from AC power. Removing power to the BIOS resets it to factory settings and involves disconnecting a small battery attached to the motherboard. On many laptops, the BIOS battery is easily accessible through a door on the bottom of the unit. Unplug the computer, remove the main battery and touch something metal to ground yourself.
Remove any screws holding the BIOS battery door in place. Then identify the battery, (it is generally a small lithium "watch" battery), and remove it taking care not to damage any surrounding circuitry. Let the computer rest for a minute or two to discharge any remaining power, and replace the battery.
If your laptop does not have an easily accessible door for the BIOS battery, you may have to dive deeper and disassemble the computer to find it. Consult your laptop manufacturer's website for information on replacing or removing the BIOS battery from your model.
  • 2 When the computer boots and the splash screen appears, tap the required function key quickly to enter the BIOS settings screen. You will only have a couple of seconds to hit the right key and if you miss it you'll have to restart the computer and try it again.
  • 3 Once you successfully enter the BIOS settings screen, use the arrow and function keys to navigate the menus. Keep an eye out for an option that says something akin to "reset to factory defaults." If you see this, follow the on-screen instructions to reset the BIOS to the factory settings. Then, confirm your choice and exit the BIOS screen, usually by pressing escape. Congratulations, you are done.
  • 4 If your BIOS does not have an option to return to factory settings, things are more difficult. Because the BIOS is stored in ROM, it must have a constant power supply to store any changes you make to it, otherwise it would reset every time you disconnected your laptop from AC power. Removing power to the BIOS resets it to factory settings and involves disconnecting a small battery attached to the motherboard. On many laptops, the BIOS battery is easily accessible through a door on the bottom of the unit. Unplug the computer, remove the main battery and touch something metal to ground yourself.
  • 5 Remove any screws holding the BIOS battery door in place. Then identify the battery, (it is generally a small lithium "watch" battery), and remove it taking care not to damage any surrounding circuitry. Let the computer rest for a minute or two to discharge any remaining power, and replace the battery.
  • 6 If your laptop does not have an easily accessible door for the BIOS battery, you may have to dive deeper and disassemble the computer to find it. Consult your laptop manufacturer's website for information on replacing or removing the BIOS battery from your model.
  • Read more: How to Reset the BIOS on a Laptop ' eHow.com http://www.ehow.com/how_4740583_reset-bios-laptop.html#ixzz1YX2FMmVc
    Sep 20, 2011 | HP Pavilion ze5375us Notebook
    I need to know how to reset bios password i have tried removing battery but never worked
    Step 1. When you first turn your computer on, you are briefly presented with a BIOS "splash" screen. Somewhere on this screen (just where depends on the manufacturer), are instructions on how to access BIOS settings. Generally, this requires tapping a function key, say F2, while the splash screen is visible. Make note of which key the splash screen says to press to access the BIOS and restart your computer.
    Step 2. When the computer boots and the splash screen appears, tap the required function key quickly to enter the BIOS settings screen. You will only have a couple of seconds to hit the right key and if you miss it you'll have to restart the computer and try it again.
    Step 3. Once you successfully enter the BIOS settings screen, use the arrow and function keys to navigate the menus. Keep an eye out for an option that says something akin to "reset to factory defaults." If you see this, follow the on-screen instructions to reset the BIOS to the factory settings. Then, confirm your choice and exit the BIOS screen, usually by pressing escape. Congratulations, you are done.
    Step 4. If your BIOS does not have an option to return to factory settings, things are more difficult. Because the BIOS is stored in ROM, it must have a constant power supply to store any changes you make to it, otherwise it would reset every time you disconnected your laptop from AC power. Removing power to the BIOS resets it to factory settings and involves disconnecting a small battery attached to the motherboard. On many laptops, the BIOS battery is easily accessible through a door on the bottom of the unit. Unplug the computer, remove the main battery and touch something metal to ground yourself.
    Step 5. Remove any screws holding the BIOS battery door in place. Then identify the battery, (it is generally a small lithium "watch" battery), and remove it taking care not to damage any surrounding circuitry. Let the computer rest for a minute or two to discharge any remaining power, and replace the battery.
    Step 6. If your laptop does not have an easily accessible door for the BIOS battery, you may have to dive deeper and disassemble the computer to find it. Consult your laptop manufacturer's website for information on replacing or removing the BIOS battery from your model.
    May 02, 2011 | Computers & Internet
    Dell Latitude D620 BIOS password help!!! I bought a Dell D620 and I noticed that some BIOS features are password protected. The previous owner said he doesn't know anything about it, so I'm not sure what...
    Dell usually sets a default password as password or admin Try those first. If no luck go into the bios setup by continually tapping the exc key while the computer boots. If your licky you may be able to set yourself as administrator and give yourself admin rights. With admin rights you can do anything.
    Nov 11, 2010 | Dell Computers & Internet
    I know bios password but i want to remove it without removing the battery
    log in bios and set bios password again hitting enter
    this will reset your current password
    Jul 09, 2009 | Acer Computers & Internet
    the battery is located on the motherboard inside the laptop, if you are not familiar with opening a laptop, i suggest you let somebody with experience do it.
    Dec 04, 2008 | Toshiba Satellite A135-S4527 Notebook
    How to reset bios password
    open the laptop and disconnect the cmos battery.wait for a minute then then replace back the battery.then post screans messages will appear.follow screen instructions.u
    Aug 30, 2008 | Acer Aspire 5100 Notebook
    HP Compaq Business nx6125 Notebook Logo
    382 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
