The adapter says DC8.4 1.1A (Max)When the camera is plugged into the power supply,(adapter) the small indicator light will flash momentarily, and then nothing.
Try www.ebay.com type make and model of camera and scroll through the list, also check any camera stores and repair facilities that may have what you are looking for.
SOURCE: Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
SOURCE: Busy message keeps flashing...wont upload photos
I posted with the same problem. I was reading the software guide that came with my camera. I ended up going to the menu on the camera and setting the camera's communication. It worked! I can now upload my pictures to my computer again.
SOURCE: Sanyo VPC-T700 Wire
1. write a letter to the company to send you a new one.do payment via credit or debit card or talk some way eith them about the payment technique.
SOURCE: camera will not connect with PC to download pictures
Hi I am vortash .. check for damage on your download lead and around the camera plug interface .. check that the drivers are still installed and reinstall them to make sure ... if you have a sd card installed remove it as it may be lose in the socket and the camera is trying to read it and can't .. check your batteries are ok .. try it on another computer .. if all this fails sounds like the camera interface has broken constant plugging in and out can sometimes cause problems with a loose plug .. hope tthis helps Regards Vortash
SOURCE: red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Currently looking into a new adapter and have contacted the Sony Corp in New York, and am waiting a reply. It is disturbing because without this camera in working order, we at this post office are limited in what services we can provide.
