Question about Bionaire BCM7204-U 3 Gallon Humidifier
Replacement filter question
Is there a replacement filter Bionaire BCM7204-U Smart Touch Cool Mist Humidifier? And where can I purchase them?
  • Anonymous Mar 26, 2014
    When I purchased the humidifier, the filter had been removed, so I need to replace it. Where can I obtain the filter?
Filter part number is BCM100. Filters are sold at Sears. Also available online. Part number is listed on bottom of humidifier.
Posted on Dec 29, 2008
I need a manual
Try google.
Humidifiers Instruction Manuals at Bionaire.com.
www.bionaire.com/...manuals/humidifiers/humidifiers-manual.html
Browse our Humidifiers Instruction Manuals to find answers to common questions about Bionaire® products. Click here to view on our FAQs now.
[PDF]Crane Owl Cool Mist Humidifier Owners Manual - Sylvane
Dec 18, 2015 | Humidifiers
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Where do I find a manual for the bionaire bcm4510-u? I would like to chance filter but no access that I can see...
You just lift up the unit and it will separate from the bottom. No screws holding it together. I had the same problem.
Jan 09, 2011 | Bionaire Cool Mist BCM4510U Humidifier
Where can I purchase a replacement filter for a bionaire BCM 1250
If you perform a GOOGLE search...type in "Bionaire BCM6010 Humidifier filters".
Also, here is a link I found on GOOGLE.
http://www.humidifierfilters.com/bionaire/filters.html
Good Luck
Oct 05, 2010 | Bionaire BCM6010 Humidifier
I dropped the tank. Whre can I get a new tank?
you can check any hardware store or if you live in canada you can check with canadian tire.
May 29, 2009 | Bionaire BCM7204-U 3 Gallon Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
Cheap filters?
Check out TotalVac.com; Great prices!!!
Jan 10, 2009 | Bionaire BCM7204-U 3 Gallon Humidifier
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Need help humidifier doesn't stay on
I've had this problem before and with mine, the issue is the water is not making its way into the correct reservoir on the bottom of the machine. With experimentation, I discovered that my tilting the machine slightly upwards on the righthand side corrects the problem (i.e. put something aprox. 3-5mm thick underneath the right side of the machine). You will hear that the water "move" to the left side of the machine and thus ensuring proper operations. I think this is a design flaw (for some machines) as clearly I have the same problem too.
Pc
Dec 19, 2007 | Bionaire Cool Mist BCM4530 Humidifier
Bionaire BCM7204-U 3 Gallon Humidifier Logo
294 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
