Question about HP Compaq Presario V2000 Notebook
USB port dont work
I have a Compaq Presario V2000 PC Notebook . Simply, my problem is my USB ports don't recognize anything I put in them ipod,HDD...nothing! Do I need to get new ports or what do I need to do?
  • Desktopsbyduck-Computers
    IS USB TURNED OFF OR ON IN THE BIOS???WHAT OS ARE YOU RUNNING.RICHARDM69
Lm 358 falt
Posted on Dec 09, 2008
My usb ports on my compaq persario co61 dont work anymore the ports dont get power aswell wat should i do
Please try these steps:
- go to the device manager - see USB ports section and right click on it - select uninstall and restart the computer
Windows should be able to reload the USB drivers and correct the issues possible caused by data corruption. If still the same, the USB ports might be having troubles not being detected in the system and there might need servicing from the manufacter or possible motherboard replacement since it was integrated with the mainboard.
Apr 10, 2011 | HP Compaq Presario V2000 Notebook
The usb ports on my v2000 no longer work. When I plug in any usb device it is not recognized.
Try reinstalling the usb drivers for your computer. You can also check to see if its a hardware issue by pluging a usb powered device like a cooling pad in the usb port. If it gets power, chances are its a software issue. If no, then its a hardware issue.
May 21, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 PC Notebook: All ports are "in use" with nothing connected. I c...
Click on start. Then click on Run.
Type in MS config.
Uncheck load startup Items.
click on ok and then click on restart.
Any application which turns on and starts using your port when the computer turns on would stop loading on their own and you will have free ports to use.
May 17, 2010 | HP Compaq Presario V2000 Notebook
Do i have a serial port on my v2000
The v2000 does not have a serial port. You would have to get a USB-Serial adapter to make that sort of connection.
Jul 02, 2009 | HP Compaq Presario V2000 Notebook
Compaq V2000 notebook freezing
you dont have much memory for your notepad. you must have at least 20% to do anything like that.
to check to see if you have at least 20% you need to do a disk defrag and than that should help.
Jul 29, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario V2000 notebook freezes
Did you reset your BIOS? sounds like your usb is not configured properly
Jul 25, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Hp pavillion usb ports
could be bad usb ports cheak bios are they enabled u could buy a pcmia card or docking stations with new ports cused by shock or gets hot fails
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
I have the same problem with my Compaq Presario V2000. Lost both USB ports and HP tells me that the motherboard has to be replaced at $300 +..I searched and found a PCMCIA card with two USB ports for $10. No problems with the USB ports on this card..great and cheap solution.
My belief is that the compaq usb ports do not have power limiting circuitry therefore allowing you to overload the output power on the ports. My ports failed after I downloaded into a burglar alarm system I was programming.
Oct 17, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
267 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
