I got a dewalt 14" blade but i need to know how the blade stays in place between the two large washer/disks?
With the bolt and first washer removed, there will be an inner washer and an arbor to centralise the blade, 14" mahines will normally have a 25.4mm arbor ( 1" ) make sure the blade you intend to fit has the same centre hole as the arbor, fit the bade onto the arbor, if there is a direction arrow fit the correct way, refit the outer washer and tighten the bolt.
