Question about Bosch SHU9915UC Dishwasher
Leaking water on floor during drain cycle
Our dishwasher leaks water all over the floor at the end of the cycle, perhaps when the machine is draining. It appears to come from the bottom left of the machine. We have had a repairman out to look and he thinks it might be a pump problem. He suggest if it is the pump that we just get a new dishwasher. Help!
  • 2 more comments
  • del8677 Dec 13, 2007
    I HAVE A MODEL KUDS230B0 AND WATER LEAKS THROUGH THE OVERFLOW WITHCHSD WHILE IT IS WASHING OR RENSING.
  • cc mac May 24, 2008
    hi..i have a bosch dishwasher that is leaking near, or at the end of the regular wash cycle. it is not quite one year old and the leaking has buckled my hardwood floor in front of the dishwasher. the plumber and the bosch authorized repair person (sent by bosch) have been here and it doesn't leak for them. the leak is on the left side, somewhere near the bottom of the door. neither of them, understandably, has been here through the entire 2 hour regular wash cycle. i don't know what to do...HELP, please. the warranty is up in a few weeks, how can i get bosch to fix it, or better yet replace it??? i don't want my entire floor ruined. the model # isSHE44c02uc/47. the ironic part is that i had a perfectly good, 18 year old kitchenaid replaced with this because i was worried that it would eventually break and ruin my hardwood floor!
  • Anonymous Aug 04, 2008
    I have th same problem when the dishwasher is draining,my repairman
    says i need to use less soap so i have and it still does iti have even
    tried a different soap. It does it about every 3 or 4 times. I have the
    repair man coming out again. The diswasher is in a vacation home and is
    used about 20 times a year. As far as i am concerned its still
    brand new. We bought it in 2002.
  • Anonymous Mar 31, 2014
    just attached, ran on 30 min cycle half way through water leaked from bottom but machine kept running
    Novelist:
  • 116 Answers
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Posted on Mar 11, 2007
  • frank Sep 11, 2013
    my dishwasher isnt leaking it just isnt draining
SOURCE:
Why is our dishwasher leaking water
There are 4 places it could be leaking. 1) at the connection where the water line connects to the dishwasher. If the dishwasher has been in operation for a long time then this is not likely to be the problem. If this were the problem you would notice water even when the dishwasher was not running. 2) at the drain hose connection. You would notice the water during and shortly after a drain cycle. The drain outlet is usually a hard plastic over which the rubber drain tube is clamped. Either the plastic could crack or the hose could dry out and crack. 3) The seal around the pump could be leaking. 4) The door seal could be leaking, though this in not usually the problem. You can probably determine the problem by removing the bottom panel so that you can see underneath the unit, and then run a cycle. There are usually 2 screws between the door bottom and the lower panel (near the sides of the machine) and 2 more screws at the
bottom of the lower panel (the recessed part of the panel) near the sides. Don't stick your hand under there because you will have power to the unit and a wet floor. That is a bad combination which could be lethal. Just shine a flashlight under and see where the water is leaking from as it runs. Remove power at the circuit breaker before trying to do any service on the unit.
Aug 22, 2014 | KitchenAid Dishwashers
Water leaking underneath pitsos dishwasher when in use
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
to replace door seal : click on door seal
Jan 12, 2013 | Dishwashers
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
Hi i have an LG dishwasher ld 1415T1 it has started leaking water at the front bottom. the rubber seal looks ok and clean any ideas Bryan
It is so common that the drain leaks in many ways and is the most problematic fault in a dish washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
please check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3/1292/how-to-replace-a-leaky-dishwasher-door-seal-h.html
Jul 29, 2011 | Dishwashers
Water leaking from bottom of dishwasher and error code e6 bush DW12-TFE3 dishwasher
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
May 28, 2011 | Dishwashers
The washer is leaking when draining begins. this occurs during the last cycle
Well, this can be from anywhere. The proceedure is to remove the bottom panel and determine exactly where the water is dripping from, then extract the machine and investigate that area. It is odd, however that ONLY the last drain cycle produces the issue, I would expect leaking on every drain cycle.
Oct 01, 2010 | Dishwashers
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Leaking from left corner GLD2250rd Frigidaire dishwasher
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Bosch SHU9915UC Dishwasher Logo
2,907 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
