Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Dishwasher does not dry the dishes thoroughly
We are having to hand-dry our dishes. The tops of the drinking items on the top shelf contain more water than usual, and the items on the bottom shelf are needing hand-dried as well. We are wondering if there is a quick fix, or a major problem we are dealing with. We stack our dishes inside the washer appropriately. Kayzy
  • Kay Stinson Feb 09, 2007
    The advice gives us some place to start on solving the problem. We are stuck on trying to first test to see if the drying vent in the door needs cleaned out behind it, before going to the possibility of the heating element being the problem. We tried to POP off the vent cover in the door, but it won't come off. It acts like it is going to break when we pry on it.
    We were told that removing the kick panel on the front of the dishwasher would reveal a packet that explains how to remove the vent cover, but these instructions were missing from the cover in that panel area. I later found the schematic info, but it appears that the whole inside panel on the door has to be removed to get to the vent cover nut holding the cover in place. We have stopped at this point as we are thinking that is more than we want to tackle on our own.
    The solutions offered were fine and timely. I think it is probably time to call in the BIG BOYS to have a look.
    Thank you for providing this service.
    Kayzy
    New Friend:
I have a GE dishwasher with poor drying. One service call said to make your water hotter and us a jet dry rinse. Not any better. Another call went to GE, this time they have a vent kit to help push out the steam and the computer will be reprogrammed to allow a longer dry time. Will have this done when the parts arrive at my home. Then the repair man will install and make computer adjustments. Looks like GE knows they have a problem but won't fix it until you complain more than once and demand a fix. For all GE dishwasher owners with this problem start calling the customer service.
Posted on Mar 22, 2013
  • 4 Answers
Had the same problem and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Posted on Apr 13, 2010
My vent cover (on my Kenmore dishwasher) is round. You have to twist it about an inch before it will pop out. I cleaned mine recently and could not believe the gunk inside there.
Posted on Jan 19, 2012
  • Mysti Williams Jan 19, 2012
    President:
  • 878 Answers
Kayzy, The dry cycle for this model, starting with 587.14432 is approx. 37 minutes. Remove the lower toe panel and have someone verify that you are getting power to the element (120V) during the dry cycle, using heated dry. If this checks ok, remove the leads from the element and ohm it out. It should read between 23 and 25 ohms. The element will be on the left side, should be easy to get at. On the inner door, remove the vent cover by popping it out and see if there is a bunch of built up gunk in there preventing a good vent. Of course make sure you are using a rinse aid and have hot water (min 120 degrees) entering the dishwasher. Check these things out first..Catriver...post back. Kay, there wasn't a complete model posted. The only model I could come up with starts with 587.
Posted on Feb 06, 2007
  • 6 Answers
Kayzy, I have the same problem but just replaced the heating element due to a silly error we made reading the ohm meter the first time we tried to determine if it was bad. Anyway, I don't think we're getting power to the element. So, what does everyone suggest for that problem?
Posted on Oct 22, 2008
After a full cycle the dishes are covered with pulverized food on top shelf only.
Most (if not all) dishwasher have a food grinder in them just like a "garbage disposal" in your sink. (It's NOT really meat to be a garbage disposal)
In any case if the ground food is ending up back in the washer it means its not being flushed out when the washer empties.
You will need to remove the bottom rack and the bottom spinner. Open the pump and clear any debris The round tank tat the lower arm sits on should also be cleaned out. If the washer is over 5 yrs old consider replacing the impeller and all the pump hardware also.
Without specific Make and Model I cannot give you detailed instructions or parts #s. When asking about things like this alway have the make and model # Good luck
Jan 22, 2017 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher inbuilt has recently stopped cleaning thoroughly. Little hard specks stuck on finished crockery, much worse on top shelf. top shelf items greasier and smeary... Cleans much better with Finish...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 26, 2011 | Dishwashers
After we wash and the dishes dry, we find grit on the (mostly) top shelf items. That is glass and cups. We check the arms they are free and not blocked. We tried lowering the top shelf, rearranging things...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 24, 2011 | LG 24 in. LDF 7811 Stainless Steel...
The dishes on the top shelf does not seem to get clean. Does not appear water is coming out of the top spinning module.
Take out the top spinner and clean it thoroughly with descaler and degreaser / very hot soapy water. Soak it for a while and it will work wonders. Put it back in the machine and it will work like new.
Sep 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Food regularly dried onto dishes, particularly bad on top shelf
try rinsing off your dishes before putting them in the dishwasher. also go to a hardware store and buy Dishwasher Magic it will clean out the dishwasher
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher
get valves on both cold and hot water coming into the dishwasher, I would first turn the cold all the off and the hot midway ....now try it. ps: it might only have a hot coming in. if still problems keep turning that hot down perhaps too much hot water is all i can think of. good luck
Aug 31, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
9,463 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
