I'm wiring a new programmable thermostat and have a wiring issue.
  • boypuck Dec 05, 2008
    Problem solved...thanks for responding & being so willing to help! Much appreciated!
  • Ken Bledsoe May 11, 2010
    What's up
  • 3 Answers
What is your issue
Posted on Dec 04, 2008
I installed a new honeywll themost and it will t witch system to cool/display shows up ut warm air till comes out/before changing did not have this issue
It sounds like you may have switched the heat and cool wires. The cool wire should be Yellow to the Y- terminal and heating wire should be the White wire to the W-terminal.
Sep 22, 2013 | Honeywell Programmable Thermostat Heater
New Digital thermostat and it will not stay above 67. I've tried the hold and to schedule. Do you think this is a wiring issue?
Not likely, if you followed the color code written on the back of the thermostat and the furnace wires were not touched the colored wires each mean something. A simple thermostat swap and matching the colored wires with the labeled terminals, it would not hurt to check the wires and terminals just for a piece of mind. I believe the issue is in the programming of the thermostat, and it is possible to get a bad one even new there is nothing that says it is in perfect working order.
Dec 29, 2010 | Honeywell Focus 6300B 5-2 Days...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
Wiring a programmable thermostat for baseboard heater
The red and black is power and neutral. Green is just for the ground and that should tie into the ground wire for breaker or power wire .
The 2 black wire from thermostat should tie into the two red and black wire from your heater.
Just imagine you are wiring 1 heater to thermostat and just add the the next heater the same way
May 15, 2017 | Honeywell Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
