Question about Panasonic Lumix DMC-FX01 Digital Camera
I would like to know how to reset my panasonic lumix DMC-FX01 back to factory settings Any tips?
  • Anonymous Feb 22, 2009
    Hey SGNath I had the same problem but with a different model. I have been trying to fix this for all most a year. Thanks, problem solved!!!!!!!!!! DN
    Scholar:
  • 170 Answers
Press the Menu/Set button and from the Setup menu, select Reset.
Posted on Feb 04, 2009
Lumix dmc-fz100
Remove the battery for 15 mins, replace the battery then go to the camera's Menu and set the Date & Time.
Mar 14, 2013 | Panasonic Lumix DMC-FX01 Digital Camera
Where can i buy a manual & user guide for a panasonic lumix DMC-FX01
I don't know about buying one, but you can download a copy for free here.
Oct 08, 2012 | Panasonic Lumix DMC-FX01 Digital Camera
Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Aug 23, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lost Lumix simple viewer C D for Panasonic Camera DMC FX01
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page.
and if you need Software CD, please contact nearest Panasonic service center.
May 15, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
When I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Apr 05, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
The lcd of my Panasonic Lumix DMC-FX01 became grey when i was taking photos. There is no problem with the photos though. The camera works without any problem. The problem is that the lcd is grey and i...
pls try to reset the camera to factory settings
performa a software reset via the menu's using the settings on the 'play' setting on the dial
if it doesnt help then
u can buy screen here and get it fixed or u can fix it is a jack mechanism inside the camera no soldering work it is not that much technical inside these devices all things are with jacks and flex cables and grips so u can do it see the link below for replacement screen from ebay and u go repair it if u go to a repair shop or panasonic they will charge u 200 $ for a 200 $ camera so dont attempt it PLS RATE ME FIXYA for help and one thing more u can check the flex cable and the connector of lcd to board may be it has some condesation and re seating might help bcoz ur LCD is not damaged as u told me no impact not broken so it might be a faulty flex cable
http://cgi.ebay.com/PANASONIC-LUMIX-DMC-FX01-FX1-LCD-DISPLAY-REPLACEMENT_W0QQitemZ220371657188QQcmdZViewItemQQimsxZ20090304?IMSfp=TL090304123003r38786
pls dont forget to rate me FIXYA
Mar 20, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
LLumix DMC-FX01
hi sir..
to fix the problem please restore the factory setting..
it will be in setting> restore factory setting> then restart..it fix the problem.. thank's sir.. please rate it.
Sep 03, 2008 | Panasonic Lumix DMC-FX1 Digital Camera
My pansonic lumix -fx01 digicam isnt responding ...seems sort of hung..
You can call  (044) 22352501
check this website for frequent issues with DMC FX01's
http://panasonic.jp/support/global/cs/dsc/faq/fx01/answer.html#q1
My only direct suggestion is to take the battery out for a few minutes and then replace it. Failing that, try running the camera with charger without battery installed.
Nov 14, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
The scene mode is in one loop!!!!!
I had this exact problem. The FX01 thought I was holding down the 'up' button! I sent it back under warranty and they replaced the board. However that doesn't mean it was unfixable; it's just cheaper for them to replace boards than test them and fix them. IMO.
Aug 06, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
1,479 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
