Question about Car Audio & Video
I have a 98 Lexus LS400. My CD player is not working now. I get a message that says ERR 1. IT sounds like the player is just spinning thru the CDs but not inserting it to play. I have a compact cartiridge magazine that holds 6 CDs. Any idea what the problem is and if it can be repaired? Thanks
  • 1,800 Answers
The eject parts is broken u need to take it apart and see if u can locate where the cd ejector jams
Posted on Dec 04, 2008
    Master:
  • 474 Answers
Well, the error is trying to tell you what is actually wrong. If you have the paper work and owners manual that came with your car, it should be in there.
Most likely it has a Jam or something broke inside. You most likely wont be able to fix it yourself as it is probably made with specialized part by lexus. But if your up for it, first look up the code and then try repairing whatever the issue is.
If you want, try this first. Dissconect your battery completely for about five minutes and then reconnect. this will reset the cars computer and cd player and time and stations and all that. yes its a bummer having to reset all that but it should clear the error code. Now clearing the error code will work if its just some stupid software error or read disk error. It could be that the laser is dirty adn just requires you going to a store and buying a disk cleaner CD whcih has lttle vrushes and will clean the laser as it plays. try that too. but if something is actually physically broken, it will come back when you try and play a cd. in that case you will know its something that requires removeing and repairing.
is this a custom CD player or was it factory install?
If its factory, you may be able to find one on Ebay rather than paying more than that to have it replaced by Toyota.
let me know what happens and if i can help further.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try loading a CD cleaner disc. This is in the hope that it is just a dirty lens. You could also try spraying with a can of compressed air the insides accessible from the catridge slot opening. Another that could be tried is to remove all the power going to unit. This is to reset the unit and revert it back to factory defaults. A friendly warning, there are some models that would require a security code before activation when the power is removed.
Another possibility is mechanical error in the loading/gearing system. While this should normally be repairable, the unit has to be removed and benchtested/repaired. The downtime and the cost of repair may make the actual repair not practical. You may have to consider other options aside from repair.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    President:
  • 2,712 Answers
Are you able to eject the CD's?
Will a power steering pump off a 98 lexus es300 work for a 98 lexus ls400?
best ask a steering specialist shop as the engine identification shows a es300 as a 1mz-fe (3.0 ltr) and a ls400 as a 1uz-fe (4.0 ltr)
there may be mounting differences between the engines
Apr 08, 2016 | Lexus Cars & Trucks
A word Err appears on sony CDP-CX53
The message is its way of telling you it is shot.
Feb 13, 2014 | Sony CDP-CX53 51-Disc CD Changer
My cd player was working fine with my cds, then it began to spit them back out reading err, I put another unit in, specifically a 98 blazer cd unit and even that unit read err with my cds, any suggestions?
CD's could need to be cleaned.
If you burned them yourself, the CD's could be
scratched are dammaged.
Unlike store bought CD's home made CD's do not have a
protective plastic coating.
Jul 11, 2011 | 1997 Chevrolet Blazer
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
1994 lexus ls 400, cd player
Hello I just purchased a 1991 Lexus LS400
I have one of those 6 cd changers and got "err" when I started up the CD.
Here is what I tried and the result
1. I took out the CD,s replaced with new ones and it played but only for a bit, then even the new CD's got the err message
2. I then though maybe dust and/ or dirt so I took out the 6 pack of CD's and blasted compressed air into the unit from a can of computer cleaner compressed air. Lost the err message but then came back
3. Read a few other ideas on the problem and then tried the old hair dryer trick. (I am a long term live a board boater and have brought back may mis-behaving electronic devices that have moisture issues with the hair drier) However the hair drier did not do away with the err message.
4. two more boating tricks I thought of... I wiped down each leaf of the CD pack with rubbing alcohol
and actually got a good deal of dirt off the plastic, finally and probably the solution I sprayed some "wire dryer" a light spray then a mist.( Wire dryer made by Gunk is a spray can of a liguid we used all the time to get cars started in the cold weather, even got a better connection by spraying on battery wires to get the sailboat diesel started with an almost dead battery.)
I Waited a few minutes put back the cd holder and it worked.
It has been about 6 hours and it is still running like a champ.
could have been the combination or just the wire dryer...not very scientific maybe it will help
Jan 12, 2009 | 1993 Lexus Ls 400
2002 Silverado- CD played ERR message
This is not a fuse problem, it may be a dirty laser lens or a broken loading mechanism, buy a CD player cleaner disk, if that won't work you will have to pull the unit out and send it in for repair at an authorized GM electronics repair station.
Nov 24, 2008 | 2002 Chevrolet Silverado
1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Oct 26, 2008 | 1992 Lexus Es 300
Lexus Cd-Changer
lol had this prob so many times, you will find that you have moisture in the cd exchanger and the way i found this out was on removing my cds first thing in the morning a noticed very slight misting on most of the cds. .i put the wifes hair dryer and blasted warm air into it for a good 15 minutes waited till it cooled down cleaaned carefully my cds replaced and away i went. hasten to add that this was temporary a few days later i got the odd cd not playing . i notice the prob more in cold weather and if the car has not been used for a few days. the boot maybe damp .. good luck .stu
Aug 19, 2008 | 1996 Lexus LS 400
Pioneer P626 car audio in 1991 Lexus LS400
With radio off I pressed the CD button and CD came on with no error code and works fine.
Feb 17, 2008 | Car Audio & Video
CD doesn't work
try different cds....some lasers in CD players are picky....make sure they are not MP3 format....worst case....Laser will need to be realligned.
Dec 27, 2007 | TruTech TRCD688 Shelf System
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
