Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Need a stacking dryer that vents from the top
Very small space to work with behind the units. Wondered if there was any stacking dryers on the market that had top vents rather than rear vents. Failing that a side vent .
    President:
  • Frigidaire Master
  • 2,651 Answers
Rear and side vents only option no machine top vents. although you can gain acces to venting through the middle panel on that unit for slightly easier mounting
Posted on Dec 04, 2008
My kenmore 98702 stacked washer/dryer washer lid does not stay open
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
May 29, 2014 | Kenmore 98702 Stacked Washer/Dryer
I have a Fridgedare front loading washer with dryer stack. There seems to be coin or other metal object behind the drum. The tech tells me he has to remove the dryer and access the washer from the top. ...
Hello Edie, thank you for your inquiry!
Generally speaking, since your washer and dryer are two separate units the dryer would need to be remove in order to access the washer. This will also help prevent any personal injuries. I do hope this information proves to be helpful.
Best regards.
Oct 05, 2013 | Frigidaire ATF6000ES Front Load Washer
DRYER PROBLEM
When the pads on the front wear, it will make noise when running. They can be replaced. There is one on the top and one on the bottom rim where the drum turns. You remove the front to access them by removing the screws on the top. Post your model number for diagrams. It's usually stamped on a small tag in a visible location on your appliance.
Washer-Dryer- behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Mar 21, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Just started last week, the dryer will dry for about 5 minutes and then it stops working.
Sounds like it is shutting down on high temp cutout,check to make sure the vent has no obstructions,(lint,kinks,vent door blocked close ect....)Also with the lintscreen removed,make sure there is'nt lint buildup under or behind it.Hope this helps
Jan 07, 2010 | Whirlpool LTE5243D Top Load Stacked...
Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore stack unit dryer not heating
Dryers usually have 2 thermal sensors a low temperature sensor and a high temperature sensor. The parts are inexpensive and if one or both are bad, they will keep the dryer from heating.
The way to check them is to use an OHM meter to see if they are OPEN. If you are using a Digital ohm meter, the setting will most likely read OL for overload.
It is most likely the low temperature sensor, but could be either. Replace both. Again, they are inexpensive and easily replaced.
To access them, you have to get to the back of the dryer and remove the panel. UNPLUG POWER before taking the back panel off. You will see 2 small rount (quarter sized) pods attached by sheet metal screws to a vent stack. One at the top and one close to the bottom. The wires should have push on connectors.
Remove the wires and check each with an ohm meter to be sure.
That is your most likely culprit.
Have FUN!
May 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Moving a large washing dryer to access vent behind
Call a friend.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer takes forever
You have a clog somewhere in the venting. Anywhere between the lint screen and the outside of the house. Use a vaccum with a crevice tool to reach behind the lint screen. Also check the flaps on the outside of the house. You can also access the machine end of the vent pipe by removing the two Phillips screws on the angled panel just below the dryer door. If you feel you need to take apart the machine further to clean behind the lint screen, write back. It's very tricky, and will take some time, but I can walk you through it.
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer Doesn't Dry Well: Take two full drying cycles.
if at all possible disconnect vent from behind machine and run a cycle with wet clothes( lint and moisture will be fllying around whih is why i said if possible) if it works then you know there a restriction in vent line leaving the home. Most problems relate to poor/ innadequate venting!!!!!!
Mar 02, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
