Question about Dewalt DC618KA Angled Nailer Kit
Dewalt dc618 wont drive a nail
Gun lights up,when you pull the trigger the motor runs,when you press it down it will not shoot a nail.the safety is not on.the plunger will not work.
  • 2 more comments
  • DIY Mike Feb 12, 2009
    DC618 Tip depresses against wood, lights come on, motor runs, nothing happens when trigger is pulled. Note: have had unit for two years, but this is first time trying to use it - basically brand new - has never fired.
  • Giant Gonads May 11, 2010
    also you can flip the safety switch on the side which will
    stop it from firing as well
  • Anonymous Mar 21, 2014
    dcc16
  • Anonymous Mar 26, 2014
    My Dewalt DC618 nailer with a fully charged battery when pressed in fully the light comes on and the motor comes on and when the trigger is depressed does nothing.
Problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Posted on Dec 04, 2008
  • 50 Answers
Its probably jammed. i have one of those and it tends to jam everyonce in a while. either that or the battery is dead. those two reasons will keep it from firing.
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
Dc618 brad gun wont fire on bump
The link below is where you can download the owners manual. The link is on that page near the top right hand side under the area marked downloads. Page 5 will show you were the switch is located that switches the tool from sequential fire to bump fire.
DeWalt DC618 parts and operations manuals
Jul 07, 2012 | Dewalt DC618KA Angled Nailer Kit
Brand new unit. Used last weekend, no problem. Today, won't shoot nail. Air is released when trigger pulled, but no nail plunged.
Orings /other parts tend to stick when nailer is new. Dewalt uses some vinyl orings that have been causing premature failure. Be sure to add a few drops of oil when used. Too much oil is not good. Wrong oil will cause orings to swell and cause problems such as yours. Your nailer's firing valve can be reset by rapping the nailer against rubber surface such as a thick rugger mat or coiled rubber air hose. Remove airline and nails, being carefull not to damage the head, rap had against rubber mat and retest gun. If it did not reset rap against nose of gun and test. If no joy, you will most likely need to remove head and manually move cylinder up/down and /or check vinyl orings for failure. Before you try to reset the gun, make sure that the safety is pushing the firing pin all the way in. Air removed, look under the trigger as you push down on safey, if it does go all the way in try bump-firing the gun (for test have nails removed). Hold in trigger and quicky /firmly strike gun against rubber pad. Good luck
Nov 14, 2010 | Dewalt D51850 Heavy Duty 20 Degree Full...
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
When you bump nailer it wont kick out nails
new safeties on nailers have to push set safety than pull trigger no more just hold trigger and bump shoot nails
Oct 06, 2009 | Dewalt Air Tools & Compressors
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Dewalt DC618KA Angled Nailer Kit Logo
2,507 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
