Question about Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer
Maytag neptune stackable washer dryer stopping
I can start the washer any were at any seting, it will shut off randomly. some times you can not get the start button to re-acivate washer, i found that if you started dyer real quick and stopped it the washer would restart after that. but still shut off at some point.
  • Anonymous Dec 28, 2008
    I have the LP version of the MLG2000AY Neptune stackable washer and dryer. Yesterday the belt fell off the washer so the water would not cycle out. My husband put the belt back on. It worked great for two loads of laundry, then on the third load the machine just shut off in the middle of the cycle. It didn't fill up with water. What can possibly be the problem with this?
    I do also have a complaint about the water not cycling out of the tub after each load of laundry. This has been a problem since day one. I leave the door open after every load so I don't have the mold problem.
    Laura
    Problem Solver:
  • 11 Answers
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Posted on Dec 28, 2008
I have a maytag neptune washer/dryer stackable. Moved hooked it up dryer works great but washer wont turn on???
Make sure you have power to the outlet, I have seen where a 110 outlet was working on either the top half and not the bottom
Jan 30, 2015 | Maytag Washing Machines
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Stops mid cycle, won't spin
You need to check and see if the door-lock light is on ,if not then you have either a faulty door lock mech. or a defective solid state board in the control panel
Dec 27, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Jun 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water problem with stackable Maytag Neptune
You have to make sure your self if water is getting through the hoses first.Remove the hot& cold hoses on the back of unit.Make sure there isn't a clog in side of the water valve screens ,if so clean them.Still not filling?Possibly a blown fuse.
Feb 09, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
MAytag MLE2000A
tellico, they had a problem with this model where it would lose the nuetral feed to the motor control. The nuetral is routed through the fill valves. The washer would just stop and shut off randomly. Have the tech check the white harness to the valves. Make sure they all have a good crimp. Sounds like you could be losing your nuetral...Catriver.. post back
Apr 21, 2007 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MLE2000A Front Load Stacked Washer / Dryer Logo
287 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
