Question about LG 30FZ1DC 30" TV
Tv not getting ON
Hi, i have a colour tv, recently one morning when i started it th e TV did not get on, instead there is a continious humming sound when the power is ON and goes off when the power is stopped. there is no clue of any sort of picture on the screen. can anyone help me out??
    Novelist:
    Champion:
  • 236 Answers
You have a short somewhere in your set.Either the power supply or the high voltage circuit. The noise is the power supply telling you that it's over loaded. You need to take it to the shop and get an estimate of repairs. Stargazer
Posted on Feb 12, 2007
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Panasonic plasma panasonic th-p42x10a green led on but tv takes long time for picture to appear
check for swolon capacitor in power supply or try to go in service mode and reset tv by pressing vol_ on tv and press recall button continious from remote tv will go to service mode then press vol_ on tv and ok from remote hold ok untill tv reset then unplug and turn on again.
Mar 06, 2012 | Panasonic TH Televison & Video
My plasma TH-42PV7HS problem is after on first ok, a few second the picture over green. some people on tv hair is green colour. HELP ME!!
this means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
Sep 13, 2011 | Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD...
When i put the tv on there is a loud humming as the tv warms the
could be a fault in the mains power-supply section,
Oct 13, 2009 | Televison & Video
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Samsung HL-S5087W DLP TV
Humming sound
the old color wheel on models pre 06 have bearings. The new replacement dosn't. The noise you here is the bad bearing. Mine got so loud I couldn't take it anymore. Just replace and noise is gone! I did mine myself. Not that hard.
Dec 21, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hi I bought a Panasonic 42 Inch class 720P Plasma HDTV TH-42PX80U, the picture is fine, but there is a humming sound in the background of the audio. The louder I turn the tv the louder the hum. I tried...
If turning up the audio amplifies the problem, it is in the initial stages of audio. It could very likely be outside the TV, try difference sources to troubleshoot your setup. If it hums on all inputs, the problem is before your audio switch and could be on the board with the AV jacks. Note all plasma tvs hum out of the back of the tv (ie power board, y-sus, z-sus board and panel all make a little hum noise)
Dec 06, 2008 | Televison & Video
The green light on for 2 seconds and off again (Panasonic TH-42PWD5UY)!
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Jan 23, 2008 | Panasonic TH-42PWD5UY 42 in. Television
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
LG 30FZ1DC 30" TV Logo
171 people viewed this question
