I own a J.C.Penney MCS Series stereo system purchased in 1997. The internal antenna (I've been told) has gone out. I can now only receive the lower frequencies. Also the there is no LED on the station numbers, so difficult to tune (this went out during move). My question: is is fixable, can I replace only the tuner, or should I invest in a whole new system? Comments and/or recommendations would be welcomeA! Thanks, Carol
  • 2 more comments
  • 4carol2 Dec 04, 2008
    The LED light disappeared in move (8 years ago).  The higher frequency stations (FM) just went.  Example I can get 90.1 an 91.7, but not 105.7 - just noise.  Other components - tape deck, CD player work fine.
    The digital read out goes up (except you can only read it with a flashlight), but there is just noise.
  • jason May 11, 2010
    also does the digital read out stop or does it go up but no station sound?
    it is not as easy as simply replacing a tuner , there is electronic components that are possibly disconnected , ( maybe someone drop it or it was bump around by the move ) but that would need to be checked to see if that happened , unless it was working after the move and went out while playing , then a component has failed possibly a tunning coil( tank ) or a zener diode that keeps the stations tuned in , either way testing will need to be done to find out whats not working , say in the fm section , is that where your having the problem?
    President:
  • 624 Answers
It is fixable, but it would require a service center to fix it. The internal antenna is not the problem, if it was bad it would not tune any stations at all, not just lower frequencies. The tuner has a problem, may need to be replaced, but it may just need some solder connections resoldered since you did mention a move. When you move, it is a very likely scenerio that the electronics could get bumped around a little. This can cause some connections to break inside the unit.
A repair would cost you from $75 all the way up to $200. No way to know for sure how much without troubleshooting the unit myself to determain the exact cause of the problem. If this unit is not worth that kind of money to repair you would be better served to just get a new one. No sense in throwing good money after bad!!!!
I hope that you have found this information help, and if so a good rating would be very much appreciated.
Thanks,
Dave
Posted on Dec 04, 2008
  • Dave DeGain
    Dave DeGain Dec 04, 2008
    You have two problems, the LCD readout and the tuner. They are not related. The readout may be an open resistor, bad voltage regulator or transistor, or even a bad bulb (if your display has a seperate backlighting.which I think your has). Then you have the tuner problem. Ther can be many reasons the tuner is not working right, all of which require troubleshooting to be certain.
Sub woofer not turning on
Is it receiving power? If not that is your answer - could be a blown fuse, bad wire, bad connection, etc.
If power is there and it still does not work then the problem coud be with a bad sub woofer on/off switch, internal fuse, or worse, blown amp from over driving.
Feb 25, 2016 | Boston Acoustics MCS 90 Horizon Series...
How do i hook up speakers to my MCS 3873 integrated stereo amplifier and 3051 quartz synthesized stereo tuner?
have fun trying to find that,why dont you just hook them up by the labels on the equipment,out means from input means to
Jul 28, 2015 | Audio Players & Recorders
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
I CAN ONLY RECEIVE 2 OR 3 RADIO CHANNELS ON MY INSIGNIA RECEIVER
Radio tuners receiving AM and FM channels/broadcast MUST have some sort of antenna connection. For local channels a paper clip will work, but for more distant channels, use either a better inside antenna or purchase a outside antenna as needed.
Jan 30, 2013 | Insignia 200W Stereo Receiver
Need to put in new deck but i have no harnessso i need the radio harness color coad
Hi Six Mcs, here are the color codes for 1997 Pontiac Grand AM
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this is what you were looking for and helps.
Mar 09, 2011 | 1997 Pontiac Grand Am
Lost remote for jc penney sterio mod#683-1938 am/fm/cassete/turntable/surround. need code to turn it on. if turned off by remote in standby mode and on/off switch will not over-ride. Intgrated into circuit...
Is this a "MCS" system from the "70's"? They stopped support in the mid "80's" I think, so all
you have for choices is a universal remote which
I doubt has a list of codes for MCS! May be another problem not letting it turn on.
Apr 15, 2010 | Audio Players & Recorders
I have a jc penney car stereo, am/fm cassette (service # 682-0392-00) that has very poor reception at its best. It is not a problem with the antenna, that has been changed and substituted with one from my...
You can purchase a in-line amplifier to boost radio signal, or just buy a new deck for less than $100 and get it installed. Great deals out there for decks below $100 installed. Try Best Buy or Fry's electronics.
Mar 15, 2010 | Car Audio & Video
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
Fm stereo
FM radio reception relies on a very good working antenna and cable, AM reception much less so. Unfortunately, the problem could be in the radio itself as there are separate signal processors in it for FM and AM. However, the most common problem is a bad cable connection at the antenna or the radio, or a bad cable itself (corroded, pinched, broken wire inside).
A couple of simple things to check: if the antenna is in the window, it may have become disconnected from the cable at the window. If the antenna is body mounted, could be a bad cable connection at the base of the antenna, and in this case, the base of the antenna could be very corroded.
You could also check the antenna cable from end to end using a continuity checker. If you can't figure that out, you could just try replacing the cable (or body mounted antenna in that case).
Dec 19, 2017 | 1997 Jeep Grand Cherokee
193 people viewed this question
 Grubhead
Grubhead
