Question about ATI ALL-IN-WONDER 2006 EDITION, (256 MB) AGP Graphic Card
NO TV on All in wonder 2006 agp
I have contacted the ATI people about not having TV in. I have an AIW 2006 agp card. With the catalyst at 8.1 and software at 6.2 by suggestion I finally got on the coax connector a messy picture, ie useless, and sound. Using the adapter connector for the composite in I still recieve no picture and no sound. I previously had a Haupauge that was nice, but had some conflicts with other components when I finally upgraded my video. I put the old video card in my other computer when I bought the AIW.
  • dontigran Jan 03, 2009
    Same Sh...
    i had all-in-wonder ATI AGP - 128MB - no problems
    And I pay money for this :
    256MB "All In Wonder ATI 2006 Edition" AGP - and no TV now... =(
    try to update drivers - and no more www.ATI.com =(
    AMD.com offering me wrong Driver (ATI 9600) i install that one
    and it dose not support TV panel... and messing up windows picture...
    and missing - "ATI T200 Unified AVStream Driver"
    Im trying to find it with out paying extra fo this st... sh...
    ya im pist...
    Scholar:
  • 40 Answers
Recently had a similar problem and solved it today!
The fix starts by first doing a "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers (observing WDM drivers).
You should have downloaded the most recent catalyst drivers from ati, and the most recent multimedia center completely (about 80+Mb) that are available for your card.
Also visit the previous versions of the catalyst drivers, the all-in-wonder 2006 seems to be only compatible with the WDM drivers up to ver.8.4 and download it "alone" (don't worry if the latest drivers include the WDM, you can write v.8.4 over it any time).
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them. DONE!
ONCE YOU'VE DONE ALL THE INSTALLING OF THE LATEST CATALYST DRIVERS AND MULTIMEDIA CENTER (is a 4 part download, be sure to install the 4 parts "only the dvd codec is optional" and leave the MMC part to install at last) BE SURE TO INSTALL V.8.4 OF THE WDM DRIVERS (for the all-in-wonder 2006), OTHERWISE YOU'LL HAVE THE SAME BLACK SCREEN WHICH IS ALSO CALLED AN OVERLAY FAIL.
Restart and run your TV, it will work. Please check if your TV comes out at 240i resolution instead of 480i, you might need to disable the TV ON DEMAND feature of the tv program. This is done at the registry. Close the TV program and Run Regedit, then look at HKEY_CURRENT_USER\Software\ATI Technologies\Multimedia\Features\DTV\Channel Manager, the Key you need to change from 0 to 1 is the one called LiveMode. Close Regedit and restart. Start the TV program, and check, you should see the 480i resolution (at the top info bar), if not press ALT+3 and then ALT+2 and then ALT+1 (don't check any of the boxes in any of the questions), that should finally do it. Any problem? Just close TV program and do it all over again from the begining more carefully or trying some little variations in the ALT part.
All this solves many problems as with the TV program showing CORRUPT and BLACK or BLANK SCREENS with AUDIO which are also called OVERLAY FAILURES in many or maybe even all of the ALL IN WONDER (PCI Express or AGP) cards and even with the TV WONDER cards and USB adapters, the only difference between the cards might be the top WDM driver version you migh be able to use with an especific card. Please watch that you might need to try all the versions of the WDM available untill you find the one that works for you (the AIW2006 uses v.8.4, but for example the TV WONDER USB2.0 is able to use the latest available.)
Posted on Jan 03, 2009
Well i put in graphic card ATi radeone 9250 agp 128 mb and then i instaled latest drivers for it including catalyst,and when i start game...any game..it crashes and i get error from catalyst center that it...
Hello
Uninstall All drivers and software for ati card. Take card out.Put card back in. Reboot pc.Reinstall drivers.I dont think the 128 mb cards Came with a fan.The 256mb did.
All the same,check your pc fans are working and clean.Also disable any onboard motherboard Graphics.You will need to do this in the bios.
Possible card was not seated right in agp slot,or drivers were corrupt.
Aug 16, 2011 | ATI RADEON® 9250, (128 MB) AGP Graphic...
1) TV audio contnues after shutting off TV 2) No Images when correctly connecting to TV
Please provide waht system you're using, ie, Dell, HP, etc., with model number, what version of windows you are currently running and, Manufacturer(Sapphire, Vision tek) and model of your graphics card. It could be outdated drivers especially if your running Windows 7.
Mar 27, 2011 | ATI ALL-IN-WONDER 2006 EDITION, (256 MB)...
Graphics driver for x1300 pro agp
Yes it will definetly works;-) go pro go ati:D
Jan 05, 2009 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
Radeon HD 3850 Video card 512 MB GDDR3,AGP8x DUEL DVI, HDTV,HDMI
If you buy an 8x AGP graphics adapter(video card) for a 4x AGP system, the card will function at 4x rate, it will still work with your system, and also download and install the latest catalyst drivers for your computer at (ATI.com)
Jan 05, 2009 | Computers & Internet
ATI All-in-Wonder 2006 PCI
I guess you are using the DOMINO interface included with the card, Be sure to connect it well to the card, a loose connection may leave you soundless too.
Remember to check that your cam is delivering audio through the composite cable you're using and connect it to a TV first to confirm that's not the problem.
Once there, confirm you can watch TV on your All-In-Wonder, if you have that same problem (audio:YES, image:NO) you may have a driver problem, which can be fixed following the next directions.
Sep 06, 2008 | ATI All-in-Wonder 2006 PCI Express ,...
ATI Radeon IGP 340mM/345M display driver or software needed..
Go here:
ATI Catalyst 8.2 - ATI Radeon - XP
Then, near the bottom of the page, click on:
Individual driver download packages, ATI Multimedia Center, Avivo™, and Korean full package and download the Catalyst Control Centre package (download 2 of 3)
Here is a direct link, but i don't know if it will re-main active:
AMD GAME! Drivers and Utilities
Then click on "Catalyst Control Center (English)"
This package will only install the ATi CCC. I personally have found that the ATI CCC doesn't like older cards, but some people have had luck getting it to work. If it doesn't work, you'll either have to find an older Catalyst Control Center, such as the one bundled with the Catalyst 4.10, or go back to using an old version of ATi Catalyst Control Panel.
Apr 29, 2008 | ATI Mobility RADEON Graphic Card
AGP texture acceleration not avalable :(
Well your card is still an ATI & things have changed a bit. You don't just need the drivers but you need ATI's Catalyst Control Center. Through the Catalyst Control Center you have a ton of control that you just don't get with drivers alone. Suggest you update windows first. You'll need .Net framework 2.0 min. Do not skip lower versions of .Net framework & only install one at a time. Install DirectX 9.0c from Microsoft here: http://www.microsoft.com/downloads/Browse.aspx?displaylang=en&categoryid=2
Than download ATI's Catalyst Software Suite File size 46.6MB:
http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html
Uninstall any other versions currently installed on your system.
If for what ever reason the uninstall fails download and run ATI's uninstaller "cat-uninstaller.exe" to clean your system from here:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Don't forget to vote!
Dec 06, 2007 | Sapphire RADEON 7000, AGP Graphic Card
ATI All in wonder 2006 editiion 256mb AGP
Download the full ati software from the site, browse the HELP, you'll find it there.
Jan 29, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
ATI ALL-IN-WONDER 2006 EDITION, (256 MB) AGP Graphic Card Logo
470 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
