Question about Epson LQ-2180 Dot Matrix Printer
Blinking all lights
A have a epsonLQ2180 and the problem is all the lights in front panel is blinking
  • len_1074 Mar 18, 2009
    lq 2180 is a dot matrix printer not a ink jet or laser printer
  • 118 Answers
Your ink absorber is full but it just a counter. you can reset it with reseter software. you can download the software here
Posted on Mar 12, 2009
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Front panel light just blinks
Hi Sharon,
Blinking of the LED at the front panel has an equivalent error code to give an idea what's going wrong to the set. Please check if there's a pattern of blinks, number of blinks separated with a pause or if the led blinks green continuously.
Jdvillanueva
Jan 05, 2012 | Mitsubishi WS-65819 TV
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
The printert dos not respiond to any cartridge and dos blink at all /
Issue: All the lights blink In this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : Blinking
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : Blinking
  • Color Start Copy light : Blinking
Figure 107: All the lights are blinking on the control panelc00864301.gif Solution one: Make sure that the front panel overlay is installed correctly If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins. NOTE: If you have already installed the front panel overlay, proceed to the next solution.
  1. Disconnect the power cord from the rear of the product.
    Please arte me Thanks Techbelkin
    TECHBELKIN ORIGINAL SOLUTION
  2. Locate the front panel overlay and peel off the paper backing to expose the adhesive as shown in the graphic below. Figure 108: Remove the paper backing from the front panel overlayc00005257.jpg
  3. Lift the scanner lid.
  4. Carefully line up and install the front panel overlay. Figure 109: Install the front panel overlayc00005258.jpg Figure 110: Correctly installed front panel overlayc00005259.jpg
  5. Reconnect the power cord to the rear of the product.
  6. Try the intended task again.
Solution two: Reset the All-in-One Follow these steps to perform a power reset. Step one: Perform a power reset
  1. Press the On/Resume button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on automatically, press the On/Resume button (c01602202.gif ) to turn the product back on.
Step two: Print a self-test report Follow these steps to print a self-test report.
  1. Load plain, white paper into the paper tray.
  2. Press and hold the Cancel button (c02517757.gif ), and then press the Start Copy Color button. The product prints a self-test report.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Service the All-in-One If you have completed all the steps and are still experiencing a problem, continue to the Service the All-in-One section at the end of this document. Service the All-in-One If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , fees might apply for contacting HP.
Jan 08, 2011 | HP PSC 1315 All-In-One InkJet Printer
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
My TV will not turn on. Power light is blinking
my 32" panasonic lcd t.v will not turn on but the red light keeps blinking in front?
Oct 12, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
RCA R52WH74 power light blinks but no power
i unfortunately cannot help you with your problem, but i have a question, how did you disconnect the front panel?
Mar 24, 2009 | Televison & Video
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Epson LQ-2180 Dot Matrix Printer Logo
744 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
