Question about Kenmore 16872 Built-in Dishwasher
Spray arms The dishwasher is filling properly and water is entering the spray arm however they do not turn. The grinder has been recently cleaned and the waterleverl checked So what could be the problem??
  • Dixiepenny Jan 10, 2008
    my spray arms won't spin either,
    Scholar:
  • 196 Answers
Sounds like the circulating pump is faulty or the spray arms hav become partially clogged. Loss of available water will stop the spray arm motion.
Posted on Jan 10, 2008
Maytag quiet series 200 dishwasher spray arms won't turn
Have you tried tighten the spray arms? They may have come lose at the fittings so need to be tightened up. You can normally tighten them with your hand. Take any traps/filters out of the dishwasher and clean them.
You may find answers here: https://www.maytag.com
Jan 15, 2013 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwasher spray arm is not spraying water. the dishwasher fills with water put won't spray. could it just be spray arm or something else
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 25, 2011 | Tappan Dishwashers
Items come out gritty
heatman101
Apr 02, 2011 | Kenmore Dishwashers
The wash spray arms are not turning the water line is free and not pinched water is on wiring is right whats up model its a ldf7920st
This sounds like your motor is not circulating properly, this will cause the spray arms not to operate properly, or at all. Are you receiving any kind of error code on the display? Also, how far is the dishwasher filling up?
Mar 07, 2011 | LG LDF6920ST Fully Integrated Dishwasher...
Top rack not cleaning properly, not sure if top spay arm is working ?
Ensure that the spray arm is movable. Inspect the spray holes in the top spray arm. If clogged, clean the openings. If no clog, position the spray arm in a certain position (e.g.: arms facing front and back). Then activate the dishwasher for a minute or so and open the door to determine if the spray arm has moved. If not, there may be an issue with the water feeding to the spray arm (typically via the water pump, etc.).
Feb 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
If the lower and upper spray arms do not turn what could be the problem? I have a MDB4100AWB and I of course have hard water in our area and wondering what is causing the spray arms to turn.
could be the plastic shaft extension that screws onto the motor shaft to drive the pump. The threads on the plastic extension would sometimes get stripped out so that even though the motor is running, it isn't driving the pump mechanism. Assuming the dishwasher is filling with water and motor is running during the wash cycle. also check spray arm openings to make sure they aren't plugged up.
Jan 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Top rack won't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
Frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Dec 22, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Kenmore 16872 Built-in Dishwasher Logo
170 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
