My CD player is unable to read the the files l burn from my laptop onto a disc, l am not sure if this is because l am not burning properly or because the files are in the wrong format
  • Casey
    Casey May 11, 2010
    What program are you burning with?
    Do you know if your cd player can play MP3's?
    Problem Solver:
  • 5 Answers
You probably will have to burn in audio file instead of mp3 to be able to play it in your cd player
Posted on Dec 04, 2008
When I try to play a CD I get an "err" message. Using store-bought CD's, not ones that have been copied. I have the Emerson PD6559BL portable CD player Love this CD player so I hope you...
Extract from your cd player manual:
"This CD player can play normal CDs p/us CD Recordable (CD-R)
and CD Rewriteable (CD-RW) discs. However the playability of CD-RIRW discs
may be affected by the type of software that was used in 'ripping' the tracks from
the original discs and 'burning' the tracks onto the blank media. Playability may
a/so be affected by the quality and condition of the blank media you use for
recording. 100% compatibility cannot be guaranteed, this is nof an indication of
any problems with your player."
So try to burn the disc with another software or buy different CD-r.
You also want to make sure that you Burned the tracks as audio files and not MP3 file, because your player can not read MP3s.
Hope this helps.
May 27, 2011 | Audio Players & Recorders
How to download mp3 music into the dvd disc
You can burn the mp3 music files to a DVD disc. Just burn the mp2 files as normal data files.
Some CD players can play mp3 music files but they need to be burnt onto a CD disc NOT a DVD disc.
Feb 26, 2011 | Computers & Internet
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
My cd/dvd drive will not burn cd/dvd's properly. it goes through the motions, but the discs come out as blank, i was able to burn cds at 2x speed, but that was it. any movie, or anything else will go...
ok..
what kind of application you use for burning??
try it again then double check if you really choose the right path of th drive you want to use as burner..
then you are sure that you burn the music as audio cd not data cd..as well as the video cd not data cd..
because if you burn data cd only computers can read that.. not your aplliances like for example your dvd player,cd,etc.
Feb 08, 2010 | Computers & Internet
I want to burn music from MP3 Rocket. It is downloaded but cannot find ANY info on the steps to burn onto CDs.
Open the music you want to burn in Windows Media player... at the top you will find an option to burn the files to disc - this will create an Audio disc that can be played in any CD player.
If you want to back up the Mp3s as data files you should simply insert an empty CD a window will pop up asking you what you want to do - select add files to CD (burn data CD) and then select the MP3s you want to burn... these files will not play on normal CD players.
If this helped you then please help me and vote kindly.
Oct 09, 2009 | Computers & Internet
Dvd-audio cd burning issue
If you are burning a "Data Disc" (the burning software should tell you or have you select it) then music will NOT work on a CD-player. It will only work in another PC.
Data disc is for files, pictures, videos, music that you want other COMPUTERS to be able to read and play.
If you want a music CD to work in a car or something like that it NEEDS to be burned as a music disc, not data.
Hope that helps.
Mar 17, 2009 | Gateway GT5056 PC Desktop
How can i burn an audio disc that will play on a cd player and not just my pc?
Modern CD players usually can read all audio disk burned on any computer system.
If you have an older model however you may experience some problem with certain settings, follow instructions below:
1 Ensure that you burn on CD support, and not a DVD, many computer drive can manage the same way CD and DVD, and burn music on DVD, but the player won't read them.
2 Ensure that you are burning an Audio CD on the cd burning, if you will just burn your MP3 files onto a disk, an ordinary CD player won't read them, unless it has MP3 capabilities.
3 If you have an old system try burning at the minimum possible speed , systems built in 80s and early 90s where limited to low speed, some 80s CD drive could read only 2x or 4x.
4 If your system is old also chose close disk after burning option on burning software, this wont affect new cd players.
You also need a software to burn CD, if you do not have burning software , see choice on websites below:
The Best, Free Alternatives to Nero CD/DVD Burner
15 Free CD/DVD burning alternatives to Nero
6 Free Alternatives To Nero | Into Windows
Mar 05, 2009 | Audio Players & Recorders
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Cd drive
media player needs configuring,select all file types.reason it wont find songs previosly burned is probably because burned as compilation and not finalised.you can download a player called VLC (for free)it will play any file type a lot of which media player cant.whatever media you have it'll play
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
