Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Clogged grease tube
The grease tube on my Jenn-Air SVE47100 is clogged and nothing is going in the jar. Is there any way to get to the tube. To make matters worse, we tried drain cleaner thinking that the tube is stainless. There is a rubber or plastic tube running along side and it expanded to twice the original size. I am afraid that the tube needs replaced. Any suggestions on how to fix this problem?
  • sjtaunton Jan 28, 2009
    I have the same clog problem but I have not put drain cleaner down it. Is there a way to clear it out without having to buy a new part?
    President:
  • Jenn-Air Master
  • 2,651 Answers
This part is labled drain cleanout 71002402, however the actual draintube part number is 74005855, retails for about $20 probably easier to replace the entire tube, and although its not real clear on the part break down id imagine its simply slid along the side of unit
Posted on Dec 08, 2008
How do you remove front panel on jenn-air sve47100
Make sure to dsc stove or be careful ... Open the oven door and look under the panel, tools that you will need are phillips screw driver and a 5 sided bolt head tool .... there's 5 screws and 2 of the other tool.
Dec 07, 2011 | Jenn-Air SVE47100 Slide-In Electric...
F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
Nov 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air cooktop drip jar
Search on-line for used appliance parts. There are some good ones out there that have the older JennAir parts in good quality used. If I can help further, I am here.
Eric Campion
Mar 03, 2009 | Jenn-Air SVE47100 Slide-In Electric...
The metal drip tube that is situated from the top part of the
if you remove the tube, it can be gently heated with a torch and the grease allowed to run out, after which, pass large amounts of hot hot water through the tube. to clean without removing, I find a speedometer cable works best to get a path through the pipe, then again, large amounts of hot hot water to flush out/clean the pipe
Feb 13, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Blower motor suction
You may want to check the venting on the unit, motor may be fine, but sounds to me like you may have a collapsed line, or a plugged line, I would also make sure nothing has gotten down into the venting chamber at the top to clog it, hope that helps
Jan 19, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I just got this Jenn Air...bought it 2nd hand in a store..how old is it?
Have a look through this lot, there are a few problems for your model discussed, but nothing that sounds like a known problem for the model; http://www.applianceblog.com/mainforums/archive/index.php/f-64.html This link has a good description of a common problem with the model (temperature too low compared to the digital readout) and it's solution; http://applianceguru.com/forum1/955.html this link has a good collection of reviews on the stove - people were still buying them new in '98, couldn't find exactly when they started selling them; http://www.epinions.com/hmgd-Ranges-Jenn-Electric-Jenn-Air_Slide-In_30-Inch_Electric_Range_SVE47100/display_~reviews If you have any problems and need parts, there are still many companies offering them online for this model - just type "jenn air SVE47100 parts" into google and you will get a good selection. Sorry I had no luck finding a user manual online, free or otherwise, you could try contacting jenn air direct to see if they could send you one; http://www.jennair.com/content.jsp?name=contact_us Hope this helps :)
Jul 06, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
469 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
