Question about Refrigerators
Require a 1000mm L x 650mm W x 860mm H chest freezer with sliding glass lids to use in an ice-cream van. Van has custom built stainless steel bench tops which I do not wish to destroy by cutting off. There is 40mm air space beside the motor and an exhaust fan through side of van drawing air-conditioned air over unit.
I am having freezer custom made.
Posted on Dec 04, 2008
The chest freezer was open wide for 24 hours before I noticed it. Will I have a problem with the unit or will it be fine
as cold air sinks to the lowest point it would have been operating a little longer that if it was closed I would think that it will be fine
example chest freezers in supermarkets only have plastic sliding lids and the ice creams and other frozen foods are still frozen
Apr 28, 2016 | Freezers
I'm making a wooden ice chest using an igloo 150qt ice chest. can I cut that lid in two and customize it to have a glass top?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are a man after my own heart.
Consider using a no shatter proof clear plastic. It is safer and easier to work with. Select an open cell gasket material (Soft rubber) for your door gasket. On the out side of your doors, using a good adhesive make a frame with steel strips to add weight to get a good seal. If you can, leave a 1" gap all round the cooler and make it air tight, air is your best insulator. You have a air gap in your hot water tank.
Glen Burnie, MD
443-306-1362
Oh, what kind of beer are you using?
Dec 19, 2014 | Freezers
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Ice Cream Server
    It is a dual thermostat unit. You could have a bad thermostat, giving you false readings.
    May 13, 2010 | Caravell 5.5 cu. ft. / 156 liter Chest...
    I need to buy a new Ice cream well/ bowl
    go to Http://www.catering-machines.com they have full list of spares or parts for Musso stella.
    All parts for the musso ice cream machine including lid, motors, gear wheels, gearbox, musso paddle Musso serial numbers start L1 = Musso piccolo L2 = Musso stella L3 = Musso Club L4 = MUSSO CONSUL.
    Apr 29, 2009 | Musso Stainless Steel Pola Ice Cream Maker
    Meat is frozen but ice cream is soft
    As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
    Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
    http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
    Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
    http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
    Refrigerator Compressor Start Capacitor and Start Relay
    http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
    heatman101
    Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
    Freezer stops and start
    ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
    Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
    Freezer not cold enough
    How is the other products in the freezer. Some ice cream doesn't get too hard and it is because of the ingridients. I can't remember now, think it is the sugar content. If your ice cubes are solid you should be ok.
    Sgt 48
    Jun 02, 2008 | LG LDN22735 Stainless Steel Bottom Freezer...
    Musso Switch
    Mar 18, 2008 | Musso Stainless Steel Pola Ice Cream Maker
    Refrigerators Logo
    46 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
