Question about PC Chips MB PCCHIPS M863G V5.1C w/XP2400+ Motherboard
System freezes when the 12v connection is made to the motherboard
The fans, HD and lights work when the 12v connection is unplgged. Nothing when it is plugged in.
Is the motherboard dead?
  • erikeuvrard Dec 04, 2008
    This is a dvr for surveillance and without the 12v power the video and audio do not work.
    Genius:
  • 1,061 Answers
Why are you plugging in if they run as you say.what is it running?Do you need it you,do not have to use every connector on the psu???RICHARDM69
Posted on Dec 04, 2008
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
Digital Sprite 2 screen freezes, reboot good for a few hours then freezes again.
check the system fans they need changing every 2 years. check the hard drive-s are not over heating should be changed every 4 years. check the psu is giving out the right volts can be checked on the hard drive plug when system is plugged in if voltage is to low 12.83v is fine 5.8volts is fine under the 12v or 5v mark it makes the system crash freeze up or just the red light flashing and a buzzing sound coming from the system. psu if you don't hear a fan going round then the psu has over heated and the power coming out will have dropped. replacement capacitors and fan can be found on the bay cheap make note were they are and replace. fan is a bearing type and costs a bit more. can use a none bearing type but it will need changing every year. 12v type think it was a 30mm or 40mm type.
Jan 30, 2013 | Dedicated Micros Digital Sprite 2 RS Video...
Ok guys I just did a new build with this system http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=281508&CatId=332 The system works fine from a cold boot. But if I...
You are new into this. Follow the step below to solve this problem.
Remove the FAN of CPU, remove the heatsink sinlk and then remvove the CPU.
Put a "Thermal Paste" on the surface of the CPU. Make sure it covers the CPU then. put the heat sink
back on followed by the fan. Turn on your motherboard and reply if this problem is till avail.
Thermal Paste can be found at RadioShack.
Please rate 4 if this solved your problem.
Apr 25, 2011 | EliteGroup ECS A740GM-M Value Socket...
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
Doesn't start. Green LED off. Red light permanently lighted.
First, try replacing the power supply. If this does not work then the motherboard will need to be replaced.
Aug 02, 2008 | Matsonic MS8137C Motherboard
Won't boot up, Fans are on non-stop
Open up the pc with power off. After cleaning with a blowing or sucking device, gently press on the connections and plug-in devices. Retry.
If no avail, the power supply or the motherboard may have bit the dust. U can get them repaired or replaced.... or save the HD and buy a another pc and add the old HD as a data disk.
May 11, 2008 | Gateway GT5056 PC Desktop
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Abit av8
Ensure that you got the cpu fan connected to the correct place, the board has 2 one for the cpu fan andt the other for a system controlled case fan.
If that dont work check to see you got the power supply connected to the board propperly, there is a seperate 4 pin connector using 2 yellow and 2 black wires ensure it is correct.
Check your power supply
unplug the power supply and bridge the green wire with the black one next to it to see if it comes on. OR JUST CHANGE THE POWER SUPPLY TO SEE IF IT WORKS.
YOUR PROBLEM IS A POWER PROBLEM EIGHTER FROM A BAD CONNECTION OR A WRONG HOOK UP AND IF NOT THAT A BAD POWER SUPPLY
Jan 03, 2008 | Abit AV8 VIA K8T800 Pro Socket 939 DDR 400...
Computers & Internet Logo
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
