I have green arcs from the bottom lower left to lower right progressively upwards a few inches apart with the lowest arc being the brightest. I am guessing "convergence" ? problem but I know nothing. I am handy and IF I can do the adjustment please tell me how. If it is a component replacement, I will call a service guy. Sony doesn't have anything on their site. The TV is about 3 years old from Good Guys so, so much for those bankrupt people. Thanks in advance. there is a way to get rid of the lines, you need to enter a code from your remote to access a hidden menu. From there you can adjust the lasers in the tv(green lines)I beleive it is very sensitive though, if done wrong can reck the tv. Not sure of the code or directions on how to exactly adjust the lasers, actually looking for them my self. Hope i was some help though!
That model is older than 3 years old. If the lines are mostly visable when you select an input (video 1,video2 etc) that has nothing connected to it and they appear as faint lines that go diagonal then an adjustment wont cure the problem. Some of those set had faulty picture tubes from day one. You might only see green right now but in the futire the red and blue will start showing the same symtom. If pressing the flash foucus and goes through the process successfully then your convergence circuit is most likely ok. The CRT's range in price and now in most cases the blue and the green are no longer availiable and have to be pulled for a rebuild. I personally wouldn't suggest anyone go into the service menu unless they know what they are doing.
Posted on Feb 06, 2007
Feb 22, 2010 | Honeywell Air Purifiers
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Oct 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dec 29, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Oct 19, 2007 | Mitsubishi WS-48313 48" Rear Projection...
May 27, 2007 | Sony KP-46WT500 46" Rear Projection...
Feb 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Jan 22, 2007 | Sony KP-51HW40 51" Rear Projection...
93 people viewed this question
No it only with an input. It also appears that the HD channels are clean. The DVD input does it with a DVD plugged in and the regular TV does it. The lowest arc is the brightest with fainter ones above it. Only green. Where is the flash focus?
