Question about Raymarine NMEA 0183 (E55059)
Raymarine rc435 hello. I just bought a RC435 to connect to a SL72 ( using nmea ) to bridge data from GPS to ST5000 autopilot via seatalk. Anyway SL72 can't "see" any data from GPS, neither trying to use Nmea in port of st5000. there are some configuration aditional to do, or, how to check step by step it in order to diagnosys where is the failure ?
    Novelist:
    Champion:
  • 202 Answers
Ripoli, This should site should help you now and in the future: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_alp.php?p_sid=8fkbDBti&p_lva=&p_li=&p_new_search=&p_accessibility=0&p_srch=&p_sort_by=&p_gridsort=&p_row_cnt=696&p_prods=&p_cats=&p_pv=&p_cv=&p_search_type=answers.search_nl&p_nav=foot&p_li=&p_page_head=1&p_page=1&p_page_foot=1 Good Luck, Tim
Posted on Feb 07, 2007
SOURCE:
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
My Raymarine ST6001+ says no signal. All other instuments are getting good GPS signal. I have have changed compass but nothing changed. I have a Course Computer 400 as the main autopilot controller. Can...
if the ST 6001 shows "no data" and alarms, the course computer is most likely bad. Control head failure is very uncommon, hower you should look at the brain box (T400) and move the control head to the other seatalk terminal (there are two) you may have just one failed SeaTalk port and can use it as is, otherwise, Raymarine will still fix (this week) 847-746-0100
Jul 11, 2009 | Raymarine St60 Plus Package, Includes...
Raymarine ST6002 Smartpilot Alarm Message ''Seatalk Fail 2''
Very possible that the Wind instrument has a defective Seatalk interface - it happened to me. You could try your Wind in another boat, just connecting it temporarily to the Seatalk Bus - if it jams those it is the problem
Your autopilot should have a separate Course Computer such as the 100, 400, S1... somewhere. Some models have two SeaTalk busses, and the recommended installation is to use one bus for the 6002 control head alone, and the other bus for instruments etc, so a SeaTalk fail on the instrument bus will not disable he Autopilot. I retired my boat this way (after the dealer took the one-bus shortcut).
The real solution is to have the Wind instrument fixed. The cheapest work-around is to cut the yellow SeaTalk wire between the 6002 and the Wind, so that the Wind instrument gets power but does not affect the data bus. That should let the AP and Wind each work normally and independently (no Wind-angle mode on the AP).
Raymarine have a forum you should join for more info and help.
Sep 05, 2017 | Raymarine Boating
Installation raymarine st6002
The power cable of your 2106 acts as a data cable also. You should find additional unused wires on the cable. Locate the brown and blue wires. You will need to connect the brown wire to the "NMEA OUT +" terminal on the autopilot course computer and connect the blue wire to the "NMEA IN +" terminal on the course computer. Finally, connect the "NMEA OUT -" and the "NMEA IN -" to ground (preferably the same place that the Garmin is grounded (black wire). Be sure that the Garmin interface is set up for NMEA In / NMEA Out. That should get you going!
Feb 20, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Sea talk failure
Remove all wiring from 4000 head, hook up only 12V, if seatalk fail continues, it is the head. if seatalk fail goes away, hook in instruments one by one until the bad head is found. Seatalk is 12V red, Ground Screen(bare wire) and Data yellow (pulsing voltage). good luck 847-746-0100 John Barry
Jul 14, 2008 | Raymarine A65 Combo GPS...
Raymarine Raychart 520 Interface to PC
you will need to hook up direct. Seatalk wont handle a waypoint download, but the chartplotter will accept the data directly into the NMEA in port. All other data, like wind depth and latlon are handled by seatalk
Mar 27, 2008 | Raymarine Raychart 520 Plus GPS Receiver
Raymarine NMEA 0183 (E55059) Logo
426 people viewed this question
Top Raymarine Computers & Internet Experts
Alun Cox
k24674
Are you a Raymarine Computer and Internet Expert? Answer questions, earn points and help others
