Question about D-Link DI 514 Wireless Router (DI-514)
I can not reset my router and can not access 192.168.0.1 to reset it through there are there any other back door ways to do it?
  • 82 Answers
Try going to 192.168.1.1 and 192.168.10.1 192.168.2.1 and 192.168.1.2 also before reseting. if those dont work you can do a hard reset. This will make all of the settings back to factory default though. So make sure you know how to/ and what the settings were before proceeding.
to do a hard reset. there is a small button on the back. Use a thumbtack or something small to push it in for ten seconds. If ten seconds dont work then try longer. i usually just sit there and listen to a song for 60 seconds with my linksys.
hope this works!
Posted on Dec 04, 2008
I JUST MOVED AND NEED HELP HOW TO RESET MY NETGEAR WGR614V9 WIRELESS ROUTER. WHAT DO I DO TO RESET MY PASSWORD TOO I THINK. thank you
Turn the router over and check the defaults on the bottom of the router. try the default admin and password to see if you can gain access to the router. Most people use the defaults so this might be a good way of gaining access. Otherwise there is usually a reset switch on the back or front of the router. You wil need a paper-clip[ to reset the switch. then you can use the defaults to gain access and reconfigure the router.
Jan 14, 2011 | NetGear WGR614 Wireless Router
I forgot the code to my router so thats why i cannot use wireless to my laptop. how can i solve this problem?
The only way you will be able to access the router is by resetting it, unfortunately there is no way of recovering your routers password. There is a reset button located on the back of the router, you may need to use a paper clip to access the reset button press and hold for 15 seconds or until router resets. Please keep in mind this will reset your router to Default settings you will want to secure your router once reset.
Jan 12, 2011 | Computers & Internet
Its because it got reset accidently and then how would i restore it back again. or can it still be restored back??
Sorry you will have to set it up again
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
hope this helps
Dec 05, 2010 | NetGear WG602 802.11g/b Wireless Access...
Cant access my linksys WRT120N router i tried the default password but its not working i need to know how to reset router password?
Merry Christmas!!!
There is a tiny switch, inside the hole, to reset the router at the back of the router, next to power jack. use toothpick and simply hold it for 5 seconds and the lights will flash signifying that the router has performed the reset.
There is one more way to reset the router if router's web page is accessible.
Use Administration -> Factory defaults link to reset the router.
Dec 01, 2010 | Linksys WRT120N Router
I forgot the password, how do i gain access to my closed router
you need to hard reset the router to factory.
small reset hole at the back. This will put the default login back on. This is the only way, careful if you do this more than like you will also wipe out your broadband settings.. which will need to be reconfigured to reconnect online
Apr 15, 2010 | Airlink AR430W Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
3com 3crwdr100a-72 how do I reset the router
For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
Dec 14, 2009 | 3Com Wireless LAN Access Point 7250...
I lost my belkin router key how can i retrieve the key
Hi theresa816,
If you lost the key, then the best thing to do is to reset the router back to it's original factory default. Usually the reset button on the back of the router, hold it down for 10 seconds, and it should reset. Then go into the router and set back up your WEP key in order to put in on your laptop or desktop for access.
Good Luck,
Mark
Nov 09, 2009 | Belkin F5D8236-4 Router
Router trouble
Try Pressing and holding the reset button on the back of the router for 30 seconds.
Mar 24, 2008 | Linksys BEFW11S4 802.11b Wireless...
Firmware Upgrade
Unfortunately, a failed firmware upgrade is the one thing you can't recover from. The only reset available on these devices is just going back to the original factory configuration. If the base software itself has been corrupted, then I'm afraid there is no way to recover. If the device is still under warranty, contact the vendor to arrange a replacement, or bring it back to the store from which you purchased it.
Sep 20, 2006 | Cnet CNIG914 Router (NWCNIG914)
D-Link DI 514 Wireless Router (DI-514) Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
