Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Frige not cooling and click noise.
My Refrigerator is making a clicking noise that is comming from the small panel that is located in the rear. It sounds like there is a timebomb in my frige. Click click, Click click. I opened the panel and there is a computer motherboard in it. The refridgerator has also stopped cooling. All of the lights work though. Any help. Thanks.
  • Anonymous Mar 12, 2014
    this is a mini-frige just out of warrantee made by Haier.
    Problem Solver:
  • 8 Answers
I fixed my motherboard.
Board WKKT Model 0158-00-04
Board GEA Part 200D4854G013
I replaced both 47uF x 400V capacitors - one of them was bulged. The bad one was open, and the other still had it's nominal value.
I tryed to make the refrigerator work, to no avail.
After a careful inspection, i replaced both 470uF x 25V capacitor (c29 and c30, i guess - near the 7805 regulator). Both had around 0.5% of their original value, and i belive it was the source of the problem.
Everytime the processor tried to start the relay, the power level dropped and the motherboard "rebooted"... and thus the cycles and clicks from the relay.
The refrigerator got back to life!
There was a recall by GE on November, 2006.
Call GE at 18003861215, option 3. Mention the recall and maybe it's still valid a free replacement.
Posted on Dec 17, 2013
  • Ted Park Mar 29, 2016
    I replaced both 47uf 400v caps and one of the 470uf 25v caps (I would have replaced both, but I only had one, the remaining one read OK) and this addressed the clicking problem. GE Profile PDS20SBSBLSS refrigerator. Also, make sure the evaporator fan hasn't croaked when you're working on your fridge.
  • 237 Answers
Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
Posted on Feb 06, 2007
    Problem Solver:
  • 5 Answers
Search google and type why is my refrigerator clicking,most sights say the start relay switch has gone bad.mines doing the same thing,if so its a 30$ fix
http://www.repairclinic.com/SmartSearch/...
Posted on Dec 12, 2007
Tip
Appliance Repair Boise - GE refrigerator making clcking noise
When you hear your GE Profile refrigerator making a clicking noise, coming from the back/rear of refrigerator, your refrigerator control board is bad. If your refrigerator and freezer are still cooling then you are lucky and you might have a few days to get that control board replaced. The clicking sound you're hearing most of the time, comes from a small panel located on the rear of refrigerator. Remove 3 screws and replace.
Rich
Western Appliance Repair Boise
on Oct 11, 2010 | Refrigerators
Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Refrigerator and freezer not cool at all
Most likely the fan that draws air over the condenser coils has burned out. It's a small fan usually toward the back of the unit on the bottom. While you're under there, be sure to clean the dirt and dust off the coils.
The fan is pretty easy to replace and doesn't cost a whole lot, so this might be a fix you can do yourself if you're mechanically inclined. There are any number of third-party manufacturers who make these fans. They're sort of 'universal' and can usually be adapted to fit just about any make and model.
Jun 11, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Kenmore refrigerator 253.57192600 making clicking noise
It could be as simple as a bit of expansion and contraction of the wall panels or the damper which allows cooling to flow from the freezer to the fridge side.
Mar 08, 2009 | Refrigerators
Not cooling
listen for the sound of a hum and a click in back of the refrigerator. If you hear the sounds your compressor has failed.
Jun 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
804 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
