Question about B&K AVR-202
My Fender Bassman 100 amp keeps buzzing.
My bass amp has an awful buzz in it.  It buzzes no matter if the knobs are at 0 or 10, whether a bass in plugged in or not.  I know it's not the cable, or the bass because I've tried several different of both.  If I play the bass it actually goes through the amp, but it's covered with that terrible, loud buzz.  Someone else on here had a similar problem with their amp, and the answer given made a little bit of sense, but I had a question about it.  He said the "cap" might be out.  I don't know what that is.  Anyway, could you please help?  This is a pretty expensive amp, and I don't have the money for a new one, or to send it to a repair shop.  I'm pretty good about fixing these kinds of problems, I just don't know what is broken for me to fix it.  Thank you very much
  • ECSizemore May 20, 2009
    After a while of that crappy buzz, the thing just quit producing sound. The light still comes on, so I know power is being received, but no sound.
  • 4,234 Answers
Part of the power supply is a filtering stage that completes the conversion from AC current to DC. The "cap" is a capacitor that furnishes voltage to help smooth the alternating current that is left from the rectifier stage. These will start to fail over time. While it is a relatively simple repair for anyone that does this for a living, I would not suggest this as your first repair. Expect a parts cost inthe $20 range plus the local labor rate for the entire repair.
Posted on Dec 04, 2008
Fret buzz only on E string. Adjusted truss and action, and still buzz. Some relief when I turn bass knob higher than the rest
This sounds like a worn nut groove. The string is sitting too low. Does the buzz happen all the way up the neck or just on open string?
Aug 14, 2013 | Dean Guitars Dean Edge E09M Electric Bass...
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
My Fishman Loudbox 100 bass speaker buzzes- what could it be? Someone suggests it could be a poor ground, and to replace the input wire, etc. Does he mean the guitar input cable? The speaker does not sound...
It is a poor ground but it is not necessarily in your amp.
If it is only buzzing when you have a guitar or other piece of equipment connected try a new lead cable.
If it buzzes all of the time......remove the cover at the rear of the amp and remove control panel.
Inspect the feed line to the input. If it is loose or or take to have repaired.
Oct 12, 2009 | Fishman Loudbox 100
Buzzing sound coming from the speaker at certain frequencies. more so when the bass is cranked. do i have to replace the speaker? or could it just be loose??
That is happening because your grounds went bad. Without grounds, then the amp will produce a buzzing sound. I would replace the input wire, that is probably the problem
Oct 11, 2009 | Fishman Loudbox 100
Keep blowing out bass on speakers Denon 75rd
Thank you for responding. I called in an audio specialist to look at the whole system--he believes there is a problem with the amplifier. Will post what he finds out when he looks inside.
May 01, 2009 | Denon DRA-375RD Receiver
Amplifier is buzzing when i plug in my les paul but ok with other
Several things to try:
- Probably already have, but another guitar cord.
- Ground switch on the amp?
- I had an older guitar that buzzed due to the pickups. While touching the strings, all was well - I was acting as the ground then. The ground wire broke, so it buzzed no matter what. The ground wire ran to the metal bridge.
- Play louder than the buzz! :)
Mar 23, 2009 | Epiphone Les Paul 100 Electric Guitar
I have a Trace Elliot bass amplifier (gp7sm 130) and it makes a buzzing soound. Any ideas?
First check all of the ground connections both at the amp and bass. If the amp makes the buzzing with no input at all, the problem is most likely a bad cap in the front end of the amp. These are not the easiest to work on. I would suggest that you bring the amp to a servicer for repair. Anything that you can describe that indicates when the buzzing is more evident would be helpful in tracking down the problem.
May 05, 2008 | Audio Players & Recorders
Guitar/amplifier 'buzz'
I have two amps .i need to know how to set the knobs on them. to get the best sound out of them .i have a crate and a drive elite.i am a beginner. they are both bass amps. so PLEASE HELP ME
Dec 27, 2007 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Feedback from bass amp
first check capeciter in rectifier stage.
Oct 16, 2007 | 3Com SuperStack II advanced RPS...
963 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
