Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Garage door opener
Will only close when you hold and maintain the button, if you let go anywhere during the process it automatically reopens and the light starts blinking, But will open correctly
  • 102 Answers
This is cause when there is something blocking one of the sensors. Look on each side of your garage door near the concrete when the door is closed and you will see small sensors that are facing each other.. Make sure they are not misaligned and that nothing is in front of them.
Posted on Dec 04, 2008
Garage door closes most of the way, then blinks and reopens
You can adjust the downward sensitivity by turning an adjustment on the opener
Nov 28, 2013 | Home Security
I have a Sears craftsman model 139.53637SRT garage door opener. My remote has not worked in a long time. I use the wall control button and have to hold the button in order to open or close the garage door....
It sounds like your door sensors may be bad or misaligned. Make sure the small light on each sensor is lit and not flickering. That could be the cause of your having to hold the wall button down until the door is closed. You can buy a universal remote but if you only had one remote before it could be the receiver that has quit. A new remote would not fix that but the only way to find out is to try.
Aug 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
When the door closes, it automatically reopens. There are no obstructions so that isn't the issue. If I disconnect the door and cycle the automatic is closes and then immediately reopens.
make sure that the auto matic reverse circuit light is being read correctly. they is a light extending a beam of infared light, you can't see it, to a reflector across the garage at the floor level at the garage opening. There should be an indicator light, usually green and red. Line up the light and reflector until the green light comes on.
Mar 08, 2011 | liftmaster Chamberlain Garage Door Opener...
Garage door wont close with remote control or home link in car. Will only close if continuously hold wall mount button during entire door travel
thanks w/d for getting right on my problem,my closer doesnt have lights at the bottom, it's a garage sale deal. works good otherwise exept I have to hold closer button on the wall to close.
Dec 14, 2010 | liftmaster Chamberlain Garage Door Opener...
When i use the keypad or internal button to close my garage it will begin to close then immediately reopen. The sensors are clear and nothing is causing the door to stop closing and reopen. What do you...
make sure the sensors are properly aligned. disconnect the opener with the saftey release and operate the door manually. be sure the door opens and closes reasonably easy by hand. If not, check for binding or broken springs or torsion springs
Oct 14, 2010 | Garden
Upon pressing open/close button kitchen door the garage starts to close but then reopens after 3-4". one must then hold button until door is fully closed. what is remedy?
The problem is that your system does NOT "see" the safety "eyes" sensors. Make sure that your sensors are properly connected to the opener (both sensors should have lights on them, one amber and another green). If they do not, check the wiring and the connections at the opener itself.
Sep 09, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Garage door opener
You need to do is shade the eyes some how for th door to work. What I did was remove them and put them up by the opener so the sun does not get to them.
Mar 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door
TRY THE DOOR MANUALLY AND RUN THE OPENER DISCONNECTED FROM THE DOOR(WITH DOOR IN CLOSED POSITION).
THIS SHOULD ISOLATE THE PROBLEM (ACTUAL DOOR PROBLEM OR OPERATOR PROBLEM).
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
IF THE DOOR STOPS/REVERSES (WITH DOOR CONNECTED) WHILE HOLDING DOWN THE WALL BUTTON TO CLOSE YOU NEED TO CHECK THE SENSITIVITY ADJUSTMENT.
HOPE THIS HELPS
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
145 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
