Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Forced air furnace will not ignit.
It is located in my attic and is horazontally mounted. I can hear and see the firing spark. I can see a pilot flame light up for a few seconds and then it goes out. I am not sure how to test or even what to test. I don't know what it is that is suppose to turn off the sparker and keep the gas flowing to the pilot.
  • 2 more comments
  • castlelakein Dec 05, 2008
    Thank you Skeeter & IdahoHAVC;
    I removed a cover for a direct view of the pilot. There is not a small probe near it. It has a typical gravity heater flame director which when it lights sends a flame sideways touching the top of the spark ignitor. The spark ignitor looks like a larger version of the one in my BBQ. Two quick points of clarification: 1. It is Carrier Model # 58EG060311 (I could not enter my request using the actual model # for some reason) 2. I observed that the pilot flame stays on as long as it is attempting to light and the sparker is operating which makes a vibrating metal noise. Normally, it would make this sound for about 10 seconds, click, and the main burner would ignite.
  • castlelakein Dec 06, 2008
    Thank you IdahoHVAC.
    Please note that my unit does not have a probe to replace. The pilot flame burns onto the top portion of the spark ignitor. The spark ignitor looks like a cigarette with a half inch wire coming out of the top.
  • castlelakein Dec 10, 2008
    Thank you IdahoHVAC,
    I called a repairman. It turns out that my spark ignitor tip, when heated by the pilot flame, sends back a signal (much like a therocouple) to the intermitent pilot control box. It turned out that both my control box and valve were shot.
    I learned a lot and I appreciate you taking the time to address my problem.
  • Ken Bledsoe May 11, 2010
    Let me ask you one thing. Is there a small probe right next to the pilot looks like a small wire?
  • 85 Answers
Skeeter is prob right your flame sensor is bad.. clean it or buy a new one, give your supplyer model number or bring it in... take a pic before disconnecting it.. If it fixes the problem, skeeter gets credit.. Thanks
Posted on Dec 04, 2008
  • 1 more comment
  • Armando Bernal Dec 05, 2008
    Take it off and replace the probe. It's bad. A local dealer or Contractor may sale you one, expect the price to be between 10 and 30 dollars, depending on your dealers mark-up.
  • Armando Bernal Dec 07, 2008
    With the ignitor there should be a sensor of some sort, thermo couple, pile, sensor. That needs replace, the probe we speak of comes in many forms...
  • Armando Bernal Dec 11, 2008
    Thanks for trying? jee thanks
How to install a spark ignitor in a gas furnace?
How to install a spark ignitor in a gas furnace? - Fixya
www.fixya.com/support/t15727344-install_spark_ignitor_in_gas_furnace
Jan 8, 2013 - How do I connect the high voltage wire to the Model 990-516 spark - Air ... SOURCE: Goodman furnace wont light, ignitor suspected. Notice.
carrier igniter
Jan 08, 2013 | Heating & Cooling
Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
My Carrier gas furnace (ser. 1903A41848) located in the attic, is five years old and suddenly won't light. IT cycles the fan when I cycle the power to the unit and seemingly attempts to ignite through 3...
try the fuse ,check the ignition element .do You have a drip leg on your gas supply line just before the gas pipe enters the furnace .if not your gas valve maybe folded .
Jan 04, 2009 | Heating & Cooling
Ignition failure after three attempts then sits for an hour.
try cleaning the burners and or adjust the distance the igniter is from the actual burner .
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Ignition failure
THE AUTOMATIC IGNITION IS TIMMING OUT BECAUSE IT WILL NOT LIGHT PROBABLY A BAD THERMOCOUPLER TRY TO LIGHT IT MANUALY
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
115 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
