Question about Dell Dimension 2400 PC Desktop
Xp takes 5min to load
I have a dell dimension 2400 takes ever to load, after installing a 512mb memory i got from my pc teacher. I had a 256 in it, by the way would the computer be faster despite the long loading with more memory.
  • hplaptop Dec 04, 2008
    Yall are wrong but thanks anyway the problem was that both hard disk stop working after 3 long loading ups simply they wont boot windows.
  • Nadine vermilya Feb 10, 2009
    freezing up
    Master:
  • 474 Answers
Yes and no.
Yes it would be faster and stop freezing on you if you have more RAM, but thats asuming you have at least the bare minimum.
Windows XP can run on as little as 256MB i have seen it, but it is slow and prone to crashing or freezing.
Minimum is 512MB- thast just to run windows, not counting any programs.
756MB is recomended, especially if you multi task.
I would never build a computer with less than a GIG ( 1024MB ) of Ram. I have 2.25 Gigs in mine, i use alot of adobe and games applications.
Regular DDR is cheap and DDR2 is actually cheaper. Depending on what you have, i would get some more.
AS for the loading when yuo turn it on, that veries. yes it will load windows faster, but it doesnt load windows untill it completes the POST check which is what it does when you first turn it on and you see the black screen with a bunch of numbers and text ( Power On Self Test ) checks all the hardware and initiates the bios.
You can change the way it boot in the bios so it will boot faster by putting the Hard drive as the first boot device. Some times if its equiped, the bios will have a pre set option for fast boot and you can set that and save it so the bios skips testing the memory and floppy drive and all that. Be carefull in the bios though, if you dont know what your doing, you can crash your system.
Hit me back if you need more help, but first get some more ram and at the fastest speed you can get
DDR gets up to 400 speed, if you have PC 2100 DDR or something like that, its slower, about 333 speed.
Let me know if you have DDR or DDR2 if its old, you may have SDIMM or something else which is alot slower, but any increase in ram is good.
Posted on Dec 04, 2008
  • 82 Answers
Some things to do to speed everything up
1) Defrag computer (start>programs>accessories>system tools>defrag)
2) run disc cleanup
(same place as defrag)
3) run virus software (ad aware and spybot search and distroy is what i would use)
4) run a registry cleaner (ccleaner is what i use)
5) turn off start up programs
( start>run. Type in msconfig. go to startup tab. Use google to see if you HAVE to have it run. some research is needed. you can post more questions in this thread for help)
6) uninstall unused programs (start>control panel. ad or remove programs. you should know what you dont use. again, use google if you dont know, or post here)
that should help out quite a bit if it is software related.
it might be that xp is messed up and need to be restored. or the hard drive is dieing, or the memory is bad. but lets knock out the easy software stuff first
  • 72 Answers
Could be a few things... how many programs do you have running at startup? start|run|msconfig try disabling un-needed programs. Also run check disk then defrag... also make sure drivers are up to date... no promises but thats where i'd start
    Sergeant:
    Champion:
  • 251 Answers
Depends on the processor size and if the memory is correctly installed
Does a 1gb nvidia 9500gt work on a dell dimension 2400
The big question is whether the 2400 has a PCI Express slot. It does not. The 9500GT is a PCI Express 2.0 x16 card
Nov 03, 2012 | Dell Dimension 2400 PC Desktop
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Very slow also to increas memory
You need more memory. If you have windows xp you need at least 512 memory.
Jul 03, 2009 | Dell Dimension 2400 PC Desktop
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Jul 26, 2008 | Dell Dimension 2400 PC Desktop
Insufficient Memory
Dear Sir
Insufficient Memory means the RAM . Please let me know How Much ram you have. By clicking task manager within that performance tab, you can view how much being utilised etc.
for better performance you should have minimum of 256 MB.
Best Regards
Rafique
Feb 14, 2008 | Dell Dimension 2400 PC Desktop
Upgrading Memory from 256 to 1GB
You shouldn't have to remove it, but if the system won't boot after try reversing the slot, and if that doesn't work take out the 256.
Feb 03, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
102 people viewed this question
Alun Cox
