Question about Texas Instruments TI-89 Calculator
How do I enter a quadratic equation into my calculator TI 89?
  • Anonymous Jan 18, 2009
    how
  • Texas Instru... Master
  • 8,016 Answers
What do you want to do with it? If you want just to enter it, you do so on the command line.
Here are exemples of solutions
Under [Mode][F2] exact/aprox set to exact
solve(x^2+x-5=0,x) finds the exact solutions the top ones
Under [MODE][F2] Exact/Aprox set to Approximate you get approximate numerical solutions, the bottom ones.
There is another command nSolve( which solves numerically for an equation. You can specify a range of values where solution is suspected to be.
Hope it helps
Posted on Sep 13, 2009
  • k24674 Sep 13, 2009
    If you know the command you can type it in, without looking in the command calatog.
  • k24674 Sep 16, 2009
    To enter an equation in your calculator you store it in a variable.
    Name the variable some thing special, to avoid conflicts with existing variables you might have created and forgotten. Let us store a quadratic equation in a variable called ekwa2;
    3x^2-0.73x+ 19/3 = 0 [STO-->] ekwa2 [ENTER].
    If you want to solve it using the solve( command you type solve(ekwa2, x) [ENTER]
    The variable x you put in the solve( command must be the same as you put in the definition of ekwa2.
3 Suggested Answers
SOURCE: My Ti-89 won't factor a quadratic equation with imaginary roots.
(a-b)3
Posted on Apr 04, 2009
  • 8016 Answers
SOURCE: HOW DO YOU ENTER r2 ON A TEXAS INSTRUMENT CALCULATOR?
No need to enter R squared. If it has meaning it will display in the stats variables screen ( 2nd F7 ).
Hope it helps.
Posted on Sep 14, 2009
How do I graph an equation with TI 89?
Just open the Y= equation editor and enter your equation. Use X for T. Make sure the angle unit is in radians.
Nov 10, 2014 | Texas Instruments TI-89 Calculator
How do i use this for algebra equations, putting in varables and such
Calculator manual: http://education.ti.com/downloads/guidebooks/scientific/30xii/30xiiqrg-eng.pdf
If you are just trying to solve a simple quadratic equation by entering coefficients, this calculator does have those features. The TI-83 is a better choice for that kind of function.
Sep 15, 2011 | Texas Instruments TI-30 XIIS Calculator
How to program the calculator TI-nspire to solve the quadratic formula
Whay would you want to go through the hassle of writing a program to solve to solve a quadratic equation`The calculator has two buit-in command to do just that. It has Solve and cSolve (for complex solutions).
Open a calculator sheet, and on the command line, type in solve(ax^2+bx+c=0, x), press ENTER and wait for the solutions
May 10, 2011 | Texas Instruments TI-Nspire Graphic...
I'm graphing a quadratic equation, I have all my info put into the stat area and nothing in the Y= area. When I graph it the points are small boxes, there is no graph line and it won't allow me to do any...
If you're doing a stat plot, you're plotting a discrete set of points. The calculator doesn't interpolate between the data points.
If you want to graph a quadratic equation, then do so. Enter it in as a Y= equation and plot it as such. This will not only connect the points (unless you tell it not to), but will also allow you to do things like trace.
Mar 03, 2010 | Texas Instruments TI-83 Plus Calculator
Singular matrix error
I had this problem as well...Were you working on a SinReg equation by any chance? I was able to do every other type of regression (Linear, quadratic, cubic, ect..) In order to get Sinusoidal regression you need to make sure you arrow down to the Period box when entering the equation, and fill it in with the number of items in your table of values (a ten item list means a period of 10). That was the fix for me, so hopefully it works for you!
Jan 17, 2009 | Texas Instruments TI-89 Calculator
IF I HAVE TWO equations 5x+8y=54, AND -9x+y=26 how do i solve
use the simultaneous equation solver software available on ur ti-89 and enter the equation in the form of augmented matrix and you will get ur answer.
Dec 03, 2008 | Texas Instruments TI-89 Calculator
Hope it helps.
Nov 12, 2008 | Texas Instruments TI-89 Calculator
How to use the texas instruments ti 83 plus
Srry my friend the ti 83 is no magnificent Ti-89. meaning: you have to solve it yourself. There is a method for graphing though. Set the equation equal to zero and then plug the stuff on the other side of the equation into a graph by pressing y= and then typing it in. Then hit graph. Wait for the graph and then hit 2nd calc and select zeros. Bring your cursor using hte arrow keys close to where the line hits the x axis and press enter and then do the same except to the right of that point and then press enter twice and it will display the y which should be the answer
There are quadratic formulas for calculators programmed in tibasic for the calc but other than that there is no way to solve it
Apr 27, 2008 | Texas Instruments TI-83 Plus Calculator
Solving multiple non-linear equations
Type it like this: solve( equation1 and equation2 and moreEquations, {list of variables to solve for})
Put all of your equations right after the opening parenthesis separated by the word and, then a comma, then within curly braces each variable you want to solve for each separated by a comma.
Apr 26, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
2,676 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
