Question about Logitech Marble Mouse PS2/USB MSLO904360
Marble mouse problems
I am having extreme problems with my computer mouse. It is behaving very erratic. This problem started about a week ago. My mouse just freezes and will not move. Once I disconnect it from the USB port and reconnect it then it will work for a little while but ultimately freezes and will not move just as before. I have a Logitech Marble Mouse which is less than two months old. I exchanged it for a new one, thinking the old one was defective, but the same problem occurs. I even tried to switch back to my original mouse but that does not work either. I have no idea what is the problem and I have attempted the troubleshooting tips from the Help and Support Center on my PC but it cannot solve the problem. I would appreciate any help with this matter. Thank you.
  • 1 more comment
  • Anonymous May 03, 2008
    same problem exactly, tried updating logitech drivers (january 2008 newest software), device manager correctly shows the trackball, claims no problems with it. Trackball problem occurs on all USB ports and on USB 2.0 hub that has its own power source...problem occurs with both older and brand new trackball.
  • SpamBusters May 03, 2008
    exact same problem. I've iinstalled newest drivers (jan 08), tried brand new trackball instead of older one, tried it in all USB ports and in self-powered USB 2.0 hub, device manager correctly shows device and claims it has no problems...yet the problem still continues
  • jmfesta Dec 14, 2008
    Same problem. Intermittent failure. Now when I plug it in, I get device not recognized errors
I have a problem like this with the marble mouse ... relatively easy workaround for me is if I simply grab the trackball with my fingers, lift it slightly out of its cradle, and put it back down, it starts working again. It would be better if there were some way to prevent it from freezing in the first place.
I had another marble mouse a couple years ago that did not have this problem. Eventually one of its button switches went bad so I had to replace the mouse. This is the replacement.
Posted on Nov 11, 2008
Need manual for marble mania extreme 2.0 cant put it together without the instruction manual?
See the link for the manual and videos. That looks like fun!
Techno Gears Marble Mania Extreme 3.0 Instruction Manual
https://www.manualslib.com > ... > Toy > Marble Mania Extreme 3.0
Translate this page
Page 2: Getting Started. GETTING STARTED BATTERY INFORMATION FOR PARENTS AND KIDS inicio INFORMACI?N DE LAS BATER?AS PARA PADRES Y NI?OS ON/OFF SwITCh INTERRuPTOR DE ENCENDIDO/APAGADO Motorized gear uses 1 "AA" (UM3/LR6) size battery, (not included). ON DEMAND BuTTON ..
techno gears marble mania extreme 2 0 instruction manual Google Search
Jan 15, 2018 | The Toys
Laptop pointer erratic
There is a setting in your Control Panel/Mouse, which is a check box to enable it to hide the mouse pointer when not in use. Disable that and see if it helps.
Sep 05, 2014 | Dell Inspiron 1545 Notebook
I have a low mileage 93 s10 Blazer with 4.3 V6 that sometimes runs smooth while at other times behaves like it has jumped timing,shakes,smokes stalls. Also the break pedal is extremely hard to push do
CK FOR A VACUM LEAK. IT SHOULD BE FAIRLY EASY TO FIND. YOU SHOULD HEAR A WHISLING SHOUND WERE THE LEAK IS CK ON THE BACK OF THEINTAKE MANIFOLD THERE IS I VACUM TEE THAT FAILS OFTEN. HOPE THIS HELPS BILL
Dec 11, 2012 | 1993 Chevrolet S-10 Blazer
Mouse behaving erratically
1. uninstall the mouse and then reinstall the mouse by restarting the PC. Upon restart the mouse should be detected as new hardware and reinstall properly and this should correct the practice behavior of the mouse.
If not then you have a mouse with faulty electronics and needs replacement.
Apr 19, 2010 | Logitech Cordless Mouse
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Logitech Marble Mouse became erratic then stopped
Nope have to throw it away and buy another. I've had this same problem every 3-4 months: works fine then it disappears from device manager then it works again at random. I end up replacing it after my curser stops moving for minutes at a time. After a few months the replacement does the same thing. My 5th replacement will be Kensington, Logitech apparently sucks
Apr 11, 2009 | Logitech Marble Mouse Trackball
When using some of the programs such as MS-EXCEL, the mouse pointer behaves as it has a mind of it's own. It starts jumping up and down and behaves erratically not allowing the control using touchpad. I...
first, try cleaning the touchpad WELL with a cloth damp with windex. If still no good, you should try to remove the keyboard, disconnect and reconnect the touchpad cable that goes to the mainboard.
hope this helps
Mar 09, 2009 | Computers & Internet
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
I HAVE A LOGITECH CORDLESS MEDIA MOUSE BOUGHT ABOUT THREE MONTHS AGO AND IT WORKED VERY WELL UNTILL A FEW WEEKS AGO WHEN THE VOLUME BUTTON STARTED TO MALFUNCTION IT BEHAVES LIKE IF IT WERE BLOCKED ON THE...
1) Do not ask questions in CAPS. It's bad form and considered rude in some forums.
2) It's a failed mouse. Replace it or call the manufacturer for replacement.
Jul 17, 2008 | Computers & Internet
Logitech Marble Mouse PS2/USB MSLO904360 Logo
168 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
