Question about Bissell 26506 Perfect Sweep Upright Vacuum
I forgot how to open my bissell power sweeper to empty it
Can't get the plastic canister off. thanks for your help.
Bissell Troubleshooting
Does the bag need changed or is there something stuck in the hose hope this helps
ddmac19
Oct 25, 2013 | Vacuums
I am looking Bissell 1631 part;Capet tool And Bissell 1640 part,Floor Nozzle
i have old bissell shampoo machine model#1630 the part i need plastic hand grap between the hose worn metal pipe.
Jun 07, 2011 | Bissell 1631 PowerSteamer ProHeat Canister...
I would like to know where i can get a manual for the bissell 3760-4 model. i bought this sweeper used and i would like to get a book on the parts . thank you for your help
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 12, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Sweeper stops running, when I jiggle the electric cord
The wiggle test is very popular and widely used. If you can gently wiggle the area that is in question and it can cause a change. Then yes, it is an electrical issue (loose wire or connection) but if not, and you have to be aggressive with the unit to get a change. Then it could be a bad motor.
Jun 11, 2009 | Filter Queen Majestic Canister Vacuum
Bissell powerforce bagless vacuum,when turned on dust flies out sweeper
Dust flying out of the sweeper indicates that their is a blockage in the pathway that the dirt normally travels to get into the dirt collection chamber. Turn the sweeper upside down and look for a blockage of some kind. Also, empty out the canister and look to see that the pathway into the canister is clear.
May 18, 2009 | Vacuums
My dyson animal sweeper just stopped running
Take it to your local vac shop and let them diagnose it. You are within warranty so if it is clogged warranty will not cover that, but everything else warranty will cover.
Jun 11, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell 9300 carpet cleaner
You put hot tap water (never boil water) into the clear bag through an opened hole in the canister. The dirty water will be correct outside of the bag. You remove the dirty water by open the valve at the bottom of the canister.
good luck
Sep 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i take off the handle release pedal on a Bissell model 8990 cleanview bagless sweeper so i can fix it ret1@tampabay rr.com
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=539036
Generic problem for all Vacuums
How do i take off
Posted by retthom on Apr 23, 2008
ret1@tampabayrr.com
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Mostly, you need to remove the top cover to the Bissell in order to get @ the handle release pedal. There could be screws on the bottom 2 or 3 screws or the top cover could be held on plastic clips or levers and they would have to be released then the top cover would come off.
This should expose the handle release pedal. If you need more information please feel free to contact your local vacuum cleaner dealer in your area in the yellow pages, or use the trouble shooting guide in the owner’s manual or you can call the Bissell factory @ the information listed below:
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Bissell 26506 Perfect Sweep Upright Vacuum Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
