Question about Jensen VM9510 Car DVD Player
Track titles How do you go about adding titles to the cd/dvd's that you are playing?
To add titles to your songs you have to do that on your computer files when you save the music and it will show up on the screen when your playing the disc. but you can not add them through the radio
Posted on Dec 06, 2008
2004 rav 4 cd player plays cd's but keeps saying No Title on Display and doesn't show track playing or error messages
all i can sugest is to disconect the battery to reset the cd player unless it has a reset button i will loke like a very small button that you can only get at with a tooth pick or similar hope this helps ivan
Sep 26, 2012 | 2004 Toyota RAV4
Tip
DVJ-X1 Cue before inserting disk.
The DVJ-X1 has a fun little bug/feature that is often over looked.
For a cd press the track forward/previous to select the track you want to play BEFORE you insert a disk, once you have the disk inserted and it initializes the deck will cue to that track automatically.
With a DVD you need to also select the TITLE as well as the TRACK most of the time with promo only or rock america disks there is only one track for videos so select TITLE 01 first then the appropriate Chapter.
on Jul 16, 2008 | Pioneer DVJX1 Turntable
CD stops at any title track but won't play
With all the problems you are having you would be further ahead replacing the compact stereo system.
Jul 23, 2012 | Audio Players & Recorders
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
HP Tochsmart DVD-RW drive not playing cd's /dvd's
The best player is Video Lan Controller (VLC) is plays everything.
You need the RIP command as you have not a data disk but a multimedia disk (.CDA) file.
Jun 13, 2017 | HP Pavilion TX2000Z Tablet PC
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
Roxio Easy CD creator 6 gives only tracks #s
I have not solved it.
Your site said that it was free and so I asked.
Thanks
Nov 18, 2008 | Roxio Easy CD & DVD Creator 6...
Playlist Trouble
Delete the track number from the ID3 tag to get around this problem. Make sure the GoGear is not set to shuffle - make sure the shuffle is OFF.
May 30, 2008 | Philips SA1100 MP3 Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Playlist problems
The only way you can get the tracks to play in order is to rename them before you put them on the player.
eg.
Album title - 01 - Track name
Album title - 02 - Track name
Album title - 03 - Track name
Album title - 10 - Track name
and so on
The albums will stay together, and the track number will put them in order within each album. Just remember to use 2 digit track numbers or they will sort 1, 10, 11, 12, 2,3,4,5,6,7,8,9
Mar 07, 2008 | Philips GoGear SA178 MP3 Player
Jensen VM9510 Car DVD Player Logo
153 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
