Question about Nokia 2115i
NOT CHARGING When plug in it says no charge STOP ?
  • 74 Answers
Dear this is hardware prob and u have to change UEM module wich is not repaing able in most of countries better choice is that u buy two battries and one universal desktop charger if any one is not reparing there.
Posted on Mar 27, 2007
SOURCE:
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Have a 1991 Buick regal,it stops charging wen I plug in temp/fuel gauge into the cluster,why would it do that?
Does it stop charging or the light just comes on/gauge goes down? Plug it in and check if the alternator is putting out 13+ volts. It could be a short in the cluster or the wire from the alternator.
Jan 27, 2015 | Buick Cars & Trucks
Plugged in not charging
On some devices, like my work Lenovo laptop, it'll stop and just trickle charge when the battery is at 97%. That's a feature, not a bug, designed to help avoid overcharging and damaging your battery and device. Try running on battery for a little while and reconnect the AC adapter. You should notice it's charging again. If it doesn't, post back.
Jan 06, 2014 | Intel Computers & Internet
My w850i is not charging when i plug in the charging mobileis hit
Check the following two things carefully:
1. is your charger working properly?(It may be found faulty)
2. is the charging port OK?
If you say that your mobile shows charging in start, and after few minutes it gives an error "charging error stop charging". Then you should confirm first that its charger is original or not. If it is not a original charger, then you should change it...Good luck :p otherwise go to mobile repairing shop.
Sep 09, 2011 | Sony Ericsson W850i Cellular Phone
I have changed my battery to new one but it says ( plugged in, not charging) how can i fix it
its normal no problems it will charge to 70 percent then power will go direct by cable not via when plugged in so batt charging will stop after certain level is reached
Aug 14, 2011 | Sony VAIO VGN-CR510E/L Laptop
Im not able to charge my phone ! When plug in the charger it shows not charging stop! Wat should i do.... Please sugest me a way to get rid of this problem..please...!
There could be 2 reasons.
1- Charging pin of the charger is not working properly.
2- The point where you put the charging pin is faulty.
Apr 25, 2011 | Nokia 1112 Cellular Phone
Battery charging with computer. Do I have to leave the unit on when it's plugged into the computer Garmin Street Pilot C330
Yes just leave the unit power ON and when the charging is done the unit will stop charging automatically.
Jun 17, 2010 | Garmin StreetPilot C330 GPS Receiver
Not working, not charging
Try to juggle the charging port, if it blinks again, then you have a broken charging cord
Jul 30, 2009 | Sennheiser VMX100 Bluetooth Headset...
Lg mobile battery indicator
Have you tried a different plug? Sounds like the plug might be bad. If you have a car charger, and a house charger, I would try both. IF one charges, and the other one doesnt, you have your answer. If you have trouble with both, then either you have 2 bad plugs, or the socket on your phone might be bad.
Either way, your local phone dealer can check them out in seconds, and some places won't even charge.
Good luck
Feb 03, 2008 | LG KG220 Cellular Phone
Nokia 2115i Logo
190 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
