Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Power supply has no output
120 volts input and no output voltage...can I get a new one ? and from where
  • 390 Answers
You can buy one from EBAY or you can buy one from HP.COM here;
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=PHOTOSMART+C4180&HP_model=Q8110A&modname=HP+PHOTOSMART+C4180+ALL-IN-ONE+(Q8110A)&template=main&plist_sval=Power+Module&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Module&catsel=Electronic+Accessories
Good Luck!
Rich Lilja
Posted on Dec 04, 2008
Hi, in Antec 300watt power supply there is 3 cables or input or current 220volt. The cables are Black, Green and white. Which one is earth, which on is live(positive) and which one is negative?
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Dec 15, 2014 | Antec Computers & Internet
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
Will there be interference if I hook a Jensen MDV6115 to a 120 volt tv?
Under no circumstances must you use a different voltage ! The power supply on these units are designed for 12v only.
However, if your question is simply referring to connecting the AV 'outputs' (i.e. yellow, red, white rca's) of your Jensen, to the AV 'inputs' of our TV, then that is fine. The AV outputs can be treated the same as any other video device.
Feb 07, 2013 | Jensen MDV6115
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Jul 27, 2017 | Reebok treadmill i-run s
My red standby light is off, checked the cord, had a power surge recently?
Good day.
This is the D.I.Y steps for troubleshooting.
  1. Open the back cover of your TV by removing all screws.
  2. Power ON the TV to perform a voltage data.
  3. Check the input voltage of power supply.It should have a 120 or 240 volts ac depends on the voltage supply from your power source.If none replace the power cord or check the main source.
  4. If you have input voltage in the power supply,check the output voltage on the power supply.It should have 5vdc,for the system board,12vdc,for the sound and 24vdc,for the back-light inverter.
  5. If you don't have output voltage from power supply board.Unplug the power cord first to check the fuse if busted,check some transistors and diodes if shorted,check some open/change value resistor and also look for leak/bulge on top capacitor.
  6. If you found any of the defective parts that mention on the step # 5 replace it with the same type and ratings.
  7. After that,try plug-in again the power cord then test the output voltage that mention on step #4.
Thank you for using FixYa and good luck.I hope this solution helps you.
Apr 18, 2011 | iLO V27DMBX Television
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Sep 01, 2010 | Inverter Xantrex MS2000 Sine Wave Charger...
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
82 people viewed this question
Ben Johnson
