Question about Nokia 6600
Menu key not working
My nokia 6600 phone having problem with menu key.it is deactivated, or when i press it's not showing any response or keypad tone is not hearing.when i used to switch on and off 2 or 3 times it got ok before 3 days. now a days it totally dead, and some times it works, for few seconds and when we get out from menu again the same problem starts. Once menu get opened I could do all jobs.i opened up the case and checked the key it is OK, then also i cleaned it, the same problem still exists. What is the problem? any virus or any hardware Ic failure or any software missing. Pls tell me a brief troubleshooting procedure. otherwise i am in trouble......
  • Airakumar Nov 25, 2008
    I have Nokia 6600. All my keys are fine but the menu key is not working. plz assist me. I cannot open my wallet which is really very important for me.
  • 65 Answers
Try to replace with a new keypad, if its symptoms persists keypad ic must be the problem
Posted on Mar 30, 2007
  • 74 Answers
Dear. wash the contents of menu key with CTC or any other approved chemical.
Posted on Mar 10, 2007
If u have checked the key pad & u hav cleand it too then its a hardware problem means problem with keypad ic it might have happend due to droping down the phone on the floor or may be due to fallen in water or may be baby might have taken the phone in mouth.
Posted on Feb 07, 2007
What is CTC and where can I get it from?
Posted on Jan 12, 2010
Dip the phone in hydrochloric acid and all your problems will be solved 4ever
Posted on Nov 28, 2008
Sell it at any price very sson
Posted on Sep 05, 2007
I would liscence key of imei356665000675967
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
Aug 10, 2010 | Nokia 6600
Not working menu key 6600 nokia
first step,you should update your phone's firmware and then clean the keytone .If nothing have changed,you can change the flexible,check the keypad track and check the keypad ic,replace if needed. And Finally,rehot the CPU or replace it.
Nov 19, 2009 | Nokia 6600
Forgot code
Got this from a blog. It received a good response. See if it works for you.
Jul 25, 2009 | Nokia 6600
Nokia 6600 problem
deactivate msg alert tone off. urs suresh9848417656
Jan 01, 2009 | Nokia 6600
KEYPAD PROBLEM
it's just keypad problem repair u r keypad.
Jul 26, 2008 | Nokia 6600
N keypad sound, enhancement logo showing
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
May 11, 2008 | Nokia 6230
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
Some keypad is not working its own duty
Use anti virus application. if problem not solved change the sim card. Thank you.
Aug 12, 2007 | Nokia 6600
Nokia 6600 Logo
429 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
