Question about Symphonic SC309D 9 in. TV/VCR Combo
Ac power Symphonic sc309D blows fuse- Dc power ok
The fuse blows instantly on the ac line, dc power works but seems to pull high current. Checked all bridge dioes and caps, none shorted. any ideas?
The most likely problem is a shorted diode, I suggest replacing them even if they do not test shorted while not under load. If it is not the diode rectifiers, there is probably a resister in the power supply that is shorted, remember also that it can also be both. Lastly, it can be a capacitor within the power supply.
I Wish You Well
Posted on May 01, 2009
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
Tip
Fuse keeps blowing (LCD,Projection,Standard,Flat panel TV.)
A blown fuse is very common on Electronics Appliances like TV's, DVD's, Receiver's etc. Sometimes fuse blew because of power surge, replacing alone with exact volt/ampere cure the problem. It is necessary to understand that blowing of fuse second time around you replaced it means that you have a shorts in the circuit.
Troubleshooting the shorted parts on the power supply section needs an experienced in electronics because you will isolate the shorted parts one-by-one. Since we are working on the power supply section (110v/220v AC) this is fatal and can cause you an electric shocked with a simple mistakes only.
Usually shorts are quite near to the AC power line where you can locate this components :
1. Power Cord - Even a very low of chances for short but still to be checked because this is a part of AC line input. This is due to frequent bending and pulling, internal wire will shorts.
2. VDR (Voltage Dependent Resistor) this serves as a guard for voltage fluctuation or excessive voltage to avoid further damaged to other parts. If there was an over voltage(reach the peak allowable voltage designed by the manufacturer) from the AC line, this parts will vary its resistanceand drive the line to excessive current which causes the fuse from blowing.
http://en.wikipedia.org/wiki/Varistor
3. Posistor (for standard TV) - connected here the degaussing coil.Check it also for shorts.
4. Rectifier Diode - Some unit this is come in bridge type package.
This is very common parts that are prone for shorts. For more info click this link
http://www.fixya.com/support/r8519792-shorted_rectifier_diode_fuse_keeps
5. Main filter electrolytic capacitor.
6. Voltage Regulator IC/Transistor.
7. H-out Transistor (for standard TV)
8. Flyback Transformer- (for standard TV)
Isolation technique is done to locate the shorted parts. Pull-out the suspected parts one-by-one in the board and test it using the ohmmeter.
Hope that it may help you find the solution on your problem.
Have a nice day!
Thanks for using fixya
JDVillanueva
on Jan 30, 2011 | Televison & Video
The incline won't recline
I will help you.please watch the videos, and use basic tools , patience , and carefully.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
LED.
With this you will fix it.
If you need further assistance, please reache, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 26, 2011 | Proform XP Weight Loss 620 Treadmill
Model 27LCDB03B-simply appears to be "dead" won't power up-not the fuse
Hello Chris, Hi, your TV's power supply section is not functioning properly. If the fuse is in good shape, then the auxiliary power section of the power supply is not functioning, this section powers the switching oscillator and IC that sends the pulse to the switching element like power transistors to create a main secondary voltage. the main secondary voltage is the circuit that produces all voltage needed source by the TV. what you can do if you are up to it.
A. Visualize any bulging capacitors, replace them. B. Measure the voltage across the following section in particular order so we can find the faulty parts.
  1. the AC input on the Power supply board. (none means open switch or power cable)
  2. the AC after the line filter circuit. (none means open line filter)
  3. the DC on the filter capacitor. (none means problem on the rectifier)
  4. then the AC on the switching element or input on the main transformer. (most likely you won't have any voltage reading hear.)if you do have continue.... (none means you scratch your head, this is the hardest part) check all low value resistors, high wattage resistors open or shorted diodes.
  5. the dc on the secondary filter capacitors.
If not have this checked by a technician, its to complicated for you.
Mar 12, 2011 | Thomson Televison & Video
My monitor (HP L1706) will not power on, NO LED indicator. After opening i found that a Capacitor ( 100uf/400v) has blown. I replaced it with 220uf/200v i was told it should work fine, but it will still...
Are you getting 160vdc voltage on that new cap?
How about the cap in the secondary DC side for the 5v and the 12vdc?
It also not good idea to double up on the capacitance since the in-rush will be higher when this cap is charged up and it can blow the main AC fuse or damage the bridge rectifiers, 10~20% higher will be OK.
When the DC filter went out, the circuits will be fed with AC and it can damage the circuits.
Service manual; http://elektrotanya.com/?q=showresult&megnev=HP&megnev2=L1706&kategoria=monitor&kat2=all
http://s807.photobucket.com/albums/yy352/budm/HP%20L1706/
Need more details on the DC reading.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Mar 03, 2011 | HP L1706 17" LCD Monitor
How come it blows 30 amp atc fuse instantly even with the system off
check connections are hooked up properly if it blowin the fuse with it off sounds like something is really wrong on inside get it checked out
Jun 04, 2010 | Kicker KX200.2 Car Audio Amplifier
Blows fuse
If the line fuse keeps blowing fuses when the unit is plugged into AC, then there is a short in the Primary side of the power supply, usually the bridge recifiters or a shorted Diode rectifier or power regulator.
Dec 15, 2009 | Televison & Video
No power when plugged in. On off button stays dark, nothing works
Everyone has problems with SMPSs; mine started in 1971 when IBM was first using them; they were literally blowing up and throwing molten copper several feet.
Anyhow, if you have the benefit of a capacitance meter with DF function, check the main filter caps all of the smaller caps. The quality and durability of electrolytics is bad and getting worse and once one of these fails anywhere in a feedback path, the supply will not start. HF is hell on electrolytics.
The (ferrite) transformer in a switcher measures very low on the Ohms scale; depending on power handling and service frequency, primary <<100 Ohms, secondary from 0.? - 10 Ohms between taps, because they operate at higher frequencies. The 50 volts from the diode bridge is way too low; you probably have failed 100-200 uFd. electrolytics right close to them although this is fairly rare since they are only working with 120 Hz. From a 120 VAC line, you should have ~ 160-170 DC volts at no load if the caps are still working as they should and you have no notable resistance between the AC and the diodes.
Well-designed switchers are wonderfully efficient and very reliable if the maker didn't cheat on component quality. I've repaired literally thousands as a sideline in a now retired business and after studying them and adding a ceramic cap.or two and better quality electrolytics, they will run for decades. At one time, I had standard repair prices on ~ 70 different models.
My guarantee was 'lifetime' and that was limited only because I retired.
Aug 20, 2009 | Toshiba SD-K760 DVD Player
JVM239WV001 Stopped working.
It could be a flame sensor, which is a thermal switch located inside the cabinet on top of the cavity (there may be two of them). One power lead should go to the fuse, the other would go to the flame sensor. Remove the flame sensor and check for continuity. If it shows open (infinite resistance), put it in the coldest part of your freezer for a few minutes, then retest. If it now reads continuity (zero resistance), replace it, put the appliance back together, and see if it works.
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Blows fuse
If you disconnect the degaussing coil and the set plays fine, it means one of 2 things is wrong. The degaussing thermistor could be shorted internally. I have seen this happen a few times on those degaussing thermistors that are in the little black boxes with 3 legs. Those boxes actually have 2 thermistors in them, one to do the actual degaussing and another connected directly across the AC to act as a heater for the degaussing thermistor. One of those thermistors could have "flashed over", which would blow the fuse the instant the set it turned on. The only other thing would be the wrong size main fuse. Without a degaussing coil the set probably draws about one amp, but the surge at turn-on with a degaussing coil could be as high as 4 amps. If you have the correct fuse installed and it blows at turn-on, replace the degaussing thermistor.
Aug 14, 2007 | Emerson EWC20D4 Combo
Symphonic SC309D 9 in. TV/VCR Combo Logo
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
