Question about Technics SCEH790 CD Shelf System
Sound Cutting Out
Hi, whenever my cd player gets up to a certain volume it cuts out as if it cant handle it, i've never had this problem before it has just started occuring. I have it plugged into my pc. Can anyone help???
  • Anonymous Dec 09, 2007
    this problem was happening to me also with the cd and amplifier. Sound was cutting out at a higher volume. Sure enough the wires had been incorrectly attached to the amplifier and so far so good. thanks for the tip, will get back to you if the problem comes back.
I had the same problem (sound was cutting out and a higher volume on the CD and radio). I took the advice given (check the wiring) and sure enough the wires from one speaker into the amplifier had been incorrectly attached. I have changed them now and so far so good.
Posted on Dec 09, 2007
We also had this same problem, make sure all speaker wires are correctly connected and have no breaks as any wire problems will cause amplifier to cut out. The system works fine now and also plays from the pc without any cut off. Hope this helps.
Posted on Apr 13, 2007
Sound keeps cutting out
take to the repairers they will handle it parfectly
Sep 05, 2017 | Toshiba Satellite L755s5246 Laptop...
1986 Thunderbird, cd player keeps cutting off. Is this power problem?
No that sounds like the player is just old and most likely needs the tiny drive belts replaced.
Apr 04, 2017 | 1986 Ford Thunderbird
Hi I have two marantz amps witch cut in and out when run from
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Jun 04, 2010 | Audio Players & Recorders
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
Receiver cuts out when playing a cd
Could be overheating, make sure nothing is blocking the vents at the top
Could be 4 ohm speaker when you need an 8 ohm-check speakers
Could undersized speaker wire. Go by some lamp cord and splice the ends and use it, do it anyway whether its the cause of the cutting out or not-it'll sound better
By a can of co-contact cleaner, unplug the receiver and spray the heck out of the circuits
Mar 16, 2009 | Audio Players & Recorders
Kenwood KDC-322 volume cutting out
there buggers rewire the earth/ground
Jun 19, 2008 | Kenwood KDC-322 CD Player
Cd player cutting out when volume is high
you prolly need a new voltage regulator
May 14, 2008 | JVC KD-G720 CD Player
Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
No sound from cd player
it may be the cords from behind the panel that have come loose or that the cd playing unit itself if gone. If you know how to, take out the head unit and disconnect and reconnect the cables/ cords the unit and see if that helps at all...because of rough road/ driving it could have loosened them enough just to cut out certain things on the unit. Hope this helped liljman1213
Sep 18, 2007 | Sony CDX-GT210 CD Player
Marantz PM4000 amp keeps cutting out
There is a fairly simple fix to this problem here: http://www.audiotoolers.com/ubbt/ubbthreads.php/topics/5316/Problems_with_Marantz_PM4000_A.html
Apr 22, 2007 | Marantz ZS5300 6-Channel Amplifier
Technics SCEH790 CD Shelf System Logo
208 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
