Question about Kenwood KR-V7080 Receiver
My kenwood amplifier suddenly off when i turn the volume high?
How to fix my kenwood amplifier when iwant to turn the volume high it always automatic shut down?
  • og_dex May 11, 2010
    what is ohms>?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 924 Answers
This is generally related to the unit getting to hot. The unit's microprocessor(computer within your receiver) will shut the unit down to protect itself from heat damage that can destroy parts. Trying running the receiver at 1/3 of your normal level. If it continue to run, the suggestion above is your issue.
Posted on Aug 08, 2015
    Problem Solver:
  • 8 Answers
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Posted on Dec 04, 2008
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
What's your problem?Kenwood kac-6295 shuts off then turns back on at high volumes
You got a (Problem) I have never heard of a amp doing that, In the 40 pus years, That i was a certified electronc technician, But like they stay you learn something new everry day,
Nov 06, 2012 | Car Audio & Video
Kenwood km-994 is to loud when volume dial is on low and will blow speakers if I turn it up
I'm no sure what you're asking. Do you mean that it goes directly from low to high immediately when you turn the dial(I'm assuming it has a dial, I haven't looked it up) or push the up or down button?
Answer is, if rotary, a bad rotary switch, or in both cases, a bad microprocessor or electronic volume.
May 02, 2012 | Kenwood Audio Players & Recorders
HAVE A KENWOOD AMP MODEL KAC-9102D . iT KEEPS SHUTTING OFF WHEN i TURN THE RADIO LOUD. ANY SUGGESTIONS
either bad ohm load or over heat if the ohs on the speaker wires to the amp are lower than specified use in the manual it will act funny cause it is pusing harder than its meant to and if it gets too hot either bad location or bad amp you can try turning the gain down a little until the amp stays on constantly at high volume
May 18, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Mar 20, 2009 | Audio Players & Recorders
I have a kenwood kc-992 home stereo amplifier and the volumes stuck on high and the volume dial is doing nothing. is there any easy solution to fixing this problem without going to a shop?
i was wondering id you would be willing to sell your control amplifier? if you are interested please contact me at marge227@hotmail.com thank you for your time!!!
Aug 13, 2008 | Kenwood Audio Players & Recorders
508 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
