Question about Canon PIXMA MP780 All-In-One InkJet Printer
Not printing and I found a component lodged in the feeding mechanism.
My printer started to make a grating&banging noise when trying to print and was pulling the paper in at a strange angle and therefore causing it to print poorly. I have pulled out a component that was lodged in the paper feed area and it still doesnt work but I imagine that is because this is a part of the printer itself. The piece I pulled out was approximately 13cm in length and was only a milimeter thick and has small threads attached to it. (it looks like a small comb). Does anyone know what this part is or had any similar problems.
  • 202 Answers
Parts falling off doesn't sound good. You may be able to find out what it is and where it goes from here: Busy week with the 780's Good Luck, Tim
Posted on Feb 06, 2007
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
HP PSC 2350 all in one printer Is not feeding properly and message reads paper jam. Paper feeds almost until it should have finished the job, but no printing at all has been done. It started making a...
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Oct 15, 2009 | Computers & Internet
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
How do a clear a carriage jam on a hp6210 printer
My HP6210 printer had the same problem. The carriage would make a lot of noise going back and forth and I got the carriage jam error message. Using a flashlight, I found an incredible amount of ink (mainly black ink) underneath the mechaism which clears the ink off the print cartridges. I throughly cleaned the internal components and it works again.
Mar 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My printer makes a loud banging noise when trying to print.
We solved the problem by buying a new printer. We figured for the cost of service, it was more economical to replace our older printer. Sad that these printers go to waste. Thanks
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
A loud banging noise from inside - as it adjusts post printing
I'd check that there's nothing that's fallen into the rear paper feed that is now causing the rollers to jam and release with the bang you mention.
If you're feeling brave I'd try holding the printer upside down (get a friend to help you and watch out for the scanner sliding out!) and give it a bit of a shake to see if anything drops out.
Jan 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Terrible grating sound when trying to print!
It could be timing issue with print head or the feed mechanism. You will have to get a service manual if you want to fix it yourself.
This link here was the only site I could find that had information on getting a service manual
Jul 31, 2008 | Epson CX4200 Stylus Color All-In-One...
Samsung SCX-4216F - loud banging noise
the doctor blade in the cartridge tobe replaced.
Jun 18, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at .
Feb 15, 2008 | HP LaserJet 1320 Printer
Reply to question
It sounds like it may be a part of your paper feeder. Hope it is under warranty. The fact that the printer only started to grind and bang when it appeared to feed the paper at an odd angle points to this to but... Is the part the same colour as the inner printer workings you can see down where the paper loads. Do you have a 2 year old in the house as they like to feed things down holes!!! It may have been a foreign part from another toy!!! Believe me this happened to a friend of mine. They had to replace the paper feeder.
Feb 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
